Input needed |
turbo7
Registered User Joined: 15 March 2009 Status: Offline Points: 233 |
Posted: 17 December 2017 at 10:49am |
So, i was thinking of building an as cheap as possible but still good sounding system.
The plan is: 6x 2x18" ported subs Fane 18XB1000 6x 2x12" ported + 1,4", so far i have been looking at Fane Sovereign 12-500 or Oberton 12450B + BMS 4554 1,4" on 60°x40° Horn This should make a serious low budget 3-way system even for large crowds, it is well scaleable, the mid highs i plan to have an -3dB of 70Hz to still maintain a bit of bass for small events. Have you got any suggestions for drivers which are cheap and still sound as good as possible ? Edit: i am specifically asking about alternatives for the 12", can also be china copies as long as they do their job nicely Edited by turbo7 - 17 December 2017 at 10:56am |
Speaker Sol
Young Croc Joined: 15 September 2009 Location: Ireland Status: Offline Points: 1320 |
I have a pair of BMS 12n620.
€200 + shipping. Pm me if you are interested. |
turbo7
thanks but much much too expensive. i am looking around the half for the 12" drivers !
smitske96
Young Croc Joined: 16 February 2016 Location: The Netherlands Status: Offline Points: 1092 |
Why 6 dual 12 above those double 18? 4 is definitely enough.
Speaker Sol
Oh sorry. I just noticed you want 6.
turbo7
Hm i dont think so ! 6x18" per side powered properly is something that cheap and therefore not too sensitive 4x12" have to keep up with. I do also like the idea of not pushing the drivers too hard and have head room. Dispersion is also an issue and it will be wider with a horizontal cluster of 3. I really need to keep price down ! Is there a good 12" which can play 70-1,2k nicely ? Probably 40 pounds per piece ? |
smitske96
I use one 12" above my TH-18 , and that's pretty balanced.
I think if you go for 4 dual 12 you leave more budget, for better 12" drivers. Dispersion wise you could go for horns with larger coverage.
turbo7
i already have had several horns, with and without phase plug etc. Still, 12" horns do not satisfy in smaller locations, they will be very large, they can not kick unless they are longer ones.
with a 6x12" ported above 6x18" i am much more versatile and equal as loud. The 12" section can do kick a lot better than too short horns, come in a smaller package and i can cross the Subbass at 90hz. I have been always much more impressed with direct radiating speakers than with 12" horns... they sound good in any venue and still deliver a lot of spl. A big plus is also the extended frequency range to meet the high frequency driver. This time it will be all reflex ! Still looking for bang for buck drivers |
smitske96
I'm not talking about a horn loaded mid section, but about the horns for the high drivers..
If you save on the 12" you definitely get les performance. As you say kick is important to you. If you go for cheap drivers, most of the time you go for less Xmax, which resolves in less displacement ---> less kick. And then we aren't talking about transient response etc.. Of course it's still advice, and it's still your decision. What i'm saying is that if you go for less, but better now. You won't regret it in the future.
doller
Young Croc Joined: 19 July 2014 Location: japan Status: Offline Points: 509 |
look at the delta pro 12a. Test one. They can kick. That said I just made 4x 2x12' 1x2' and bul tweeter. Tuned the box to 70hz. lacks kick I think. and I would agree with your coverage coment. 6 would be nice and wide. The subs will stuggle to keep up. I think.
