  New Posts New Posts RSS Feed - Insane Halfinator with DSP, bluetooth and lithium
puzo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote puzo Quote  Post ReplyReply Direct Link To This Post Posted: 30 August 2021 at 1:59am
Hi, in the process of building a halfinator.  What’s the dimensions of the port?
Thanks
Edited by puzo - 30 August 2021 at 2:00am
lutkeveld View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote lutkeveld Quote  Post ReplyReply Direct Link To This Post Posted: 01 September 2021 at 8:51pm
56mm inner diameter, 66mm long
SamV View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SamV Quote  Post ReplyReply Direct Link To This Post Posted: 06 September 2021 at 6:41pm
Brilliant work!
puzo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote puzo Quote  Post ReplyReply Direct Link To This Post Posted: 07 September 2021 at 9:45pm
Thanks, onto cutting,
puzo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote puzo Quote  Post ReplyReply Direct Link To This Post Posted: 30 September 2021 at 1:23pm
hi lutkuveld,
one more question, whats from side and from top center for drilling the port hole
thanks  aeddon
Post Options Post Options   Thanks (0) Thanks(0)   Quote lutkeveld Quote  Post ReplyReply Direct Link To This Post Posted: 30 September 2021 at 8:08pm
Does not really matter, pick something that fits and looks good :)
puzo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote puzo Quote  Post ReplyReply Direct Link To This Post Posted: 03 April 2022 at 3:03pm
Hi
I’m in the uk and for the life of me I can’t find any tube that’s 56mm internal diameter.
Is there a simple port calculator I could use to work out a replacement. Say input a diameter and get length.
How crucial and precise the port dimensions are
Is there a replacement I’m people have used?
Thanks. Aeddon.
Post Options Post Options   Thanks (0) Thanks(0)   Quote lutkeveld Quote  Post ReplyReply Direct Link To This Post Posted: 03 April 2022 at 3:31pm
What tube diameter can you find?
One or two mm will not make that much of a difference.
Edited by lutkeveld - 03 April 2022 at 3:32pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote toastyghost Quote  Post ReplyReply Direct Link To This Post Posted: 03 April 2022 at 6:12pm
puzo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote puzo Quote  Post ReplyReply Direct Link To This Post Posted: 04 April 2022 at 11:18pm
What I have on hand are
63.2mm ID
52mm ID
Plus the above 57mm ID pipe ( thanks for the link)
Edited by puzo - 04 April 2022 at 11:20pm
simulatoren View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote simulatoren Quote  Post ReplyReply Direct Link To This Post Posted: 06 January 2024 at 3:45am
Hi
Do you have the specs for the DSP? I'm currently in the process of building a similar setup with the 407n's
