  New Posts New Posts RSS Feed - internal crossovers
internal crossovers
soundgodwannabe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote soundgodwannabe Quote  Post ReplyReply Direct Link To This Post Topic: internal crossovers
    Posted: 30 May 2005 at 11:29am
The bass reflex cabinets that I am using now, use an internal crossover between the input jacks and the woofer. I didn't see any mention of using an internal crossover in the plans.
Is anyone using them? Is it needed?
Make the soundman mad and I WILL press the suck button for your band.
Dom View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dom Quote  Post ReplyReply Direct Link To This Post Posted: 30 May 2005 at 12:24pm
You aren't going to get a passive crossover that can handle the sort of power you should be putting into an X1...
A crossover is needed though.  You need to run active.
Timber_MG View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Timber_MG Quote  Post ReplyReply Direct Link To This Post Posted: 30 May 2005 at 2:45pm
Sorry, but if your needs dictate a cab like the X1, a passive crossover should not come into considderation even. Also refer to another thread on this forum about "standard practice" with non-speakon speaker connectors (sorry)
@Dom: there is always the alternative of using a five finger discount on transformer boxes at the local power substation if passive filters are really needed.
