iNuke 6000/12000DSP |
taurusty
Registered User Joined: 09 January 2007 Location: Jamaica Status: Offline Points: 473 |
Posted: 14 October 2016 at 2:35am |
Hey!
Anyone know how to check firmware in iNukes? And how to do the update? I downloaded FW 1.3 off the site, no instructions only a release note. The editor (which is where I wudda thot FW updates would start) has no such option. Clicking on the .exe FW file opens & closes a window very fast. I use WIN 10 so I dunno if that's the issue, but I can't find any info on Berry site or via Google. Anybody else experienced this? Edited by taurusty - 14 October 2016 at 2:35am |
odc04r
The firmware comes as an application file so with the INuke correctly connected to the PC that is all you should need to install it. If it was designed to be uploaded via the editor s/w then the firmware file would be a binary data file such as .bin or similar.
It is probably a W10/Berry software issue, but I can't help with that sorry, |
taurusty
Thanks ODc4r. I really wanted to check the amp 1st, but the start up only shows iNuke on the screen. No mention of how to ck it in documentation...
jammin75
Old Croc Joined: 08 July 2012 Location: west midlands Status: Offline Points: 2375 |
*To update the iNUKE DSP Amplifiers press SETUP while switching the unit on and run the iNUKEusbupdate_V1-1.exe.
taurusty
Yep! That works! Maximum respect Jammin. I'll have to relay that to Berry CS 'cos they wrote me that 'they will have to investigate"!!!
Thanks again, Jammin, that's what this community is all about! Edited by taurusty - 14 October 2016 at 5:22pm |
jammin75
no problem if i flash my 6000 dsp will it be 2ohm stable
