Inverted speakers |
king david
Young Croc Joined: 17 January 2007 Location: italy Status: Offline Points: 1324 |
Posted: 28 October 2020 at 1:46pm |
Hi
Wondering whats the difference in inverted speakers in some bandpass horns, is it better cooling or more? For example es18 bph has driver inverted compared to classic turbosound bins - and different dimensions Funktion one f218 and 215 have driver inverted between mk1 And mk2 and same (external) dimensions, is it just a matter of turning the driver on the other Side? Would it Last longer or play any different like less distortion or power compression?
fatfreddiescat
Young Croc Joined: 15 October 2010 Location: N.E.Wales Status: Offline Points: 1081 |
It's to reduce power compression, it was done after I had had a meeting with Tony and suggested he give it a try.
king david
So is it same design just inverted speaker?
fatfreddiescat
I would guess that the chamber volumes would have been adjusted to compensate and possible change of baffle angle etc so driver would physically fit.
king david
Yeah. I did try something like that more than 10 years ago on a tse118 chopboard copy i got for free. Some magnets fit some didnt...
fatfreddiescat
Potential you could use a spacer ring to offset the driver?
