Is it a upgrade? |
Post Reply | Page 12> |
LjudLahger
Young Croc Joined: 31 July 2008 Location: Sweden Status: Offline Points: 838 |
Posted: 14 May 2021 at 2:51pm |
I got 2x PD.121 with XT1086 on a DE500 comp, reflex, in my tops. I found P.audio BM-D750 s2 and ph-642 on a sale and as I never owned a 2”, this got me going...
But is this somewhat a upgrade or downgrade? Today I cross at 1500hz and thougt that a 2” could bring the x point lower. Give me an advice please.
Edited by LjudLahger - 14 May 2021 at 2:52pm |
Earplug
I've got BM-750's (Series I) on various 2x12" & 1x12" cabs - and they are very, very good. A friend and I tested them against the B&C version () - and they sounded better - louder & "smoother". I'd say go for it! |
Sinai Sound
Young Croc Joined: 09 November 2009 Location: Sheffield Status: Offline Points: 631 |
Try a BMS 4550 ;)
That will allow you to bring the x-over down to 1khz
LjudLahger
Interesting! Thank’s for your input
LjudLahger
That 4550 looks nice, but when I got the de500’s they wore highend and I like them alot. It’s really a question of going 2” with bm-d750 :-)
But the spec say 1000hz rek xover...can you go lower?
Earplug
Why would you want to go lower? I think that the lower mid-top frequencies are better reproduced by a cone. An alu or titanium diaphragm will sound harsh at those frequencies. Historically, you can find cabs that used comp drivers with 600Hz-800Hz xover frequencies - but I think that there is a reason that practice ended! |
FOO
Young Croc Joined: 23 December 2018 Location: Denmark Status: Offline Points: 813 |
You see more and more active driven speakers loaded with larger HF drivers, and lowered Xover freq. And from personal experience, there are quite a difference.
RCF ART 732, 735 and 745 are good examples.
LjudLahger
Your words are true...
I guess that I have some memory of “beaming” and “you want to x as low as possible to prevent this”. But I have never heard any problems. I’m only after something new to build I guess :-) |
ceharden
It will sound different but whether it could be considered an upgrade or downgrade is hard to say.
In terms of the sound of the HF itself, the DE500/XT1086 will probably sound better, especially at the high end. Whereas with a larger CD and lower crossover point, you might get better integration with the 12". It will really depend what you use the cabs for and what kind of sound you're looking for.
Meat Substitute
Registered User Joined: 10 July 2020 Status: Offline Points: 79 |
I've not tried that driver on that horn but I've tried a pair few others and it always sounded very good. I like larger format drivers nowadays. I was well into doing 12+1 but now prefer 15+2 (maybe I got old and lost the top range or something) 1" sounds good but the impact of a 1.4" or 2" is a lot more. As Chris says above, it'll all depend on your integration - if it wants a 1" in your design then fine also.
taurusty
Registered User Joined: 09 January 2007 Location: Jamaica Status: Offline Points: 473 |
Edited by taurusty - 16 May 2021 at 2:42pm |
taurusty
This!
P Audio BMD 750II can go as low as 800Hz with the right horn, but remember power handling is affected. I cross mine at 1200hz 48dB/oct. Never had an issue |
