Is it nessicary to seal drivers with gasket tape? |
sarsen1 ![]() Registered User ![]() ![]() Joined: 01 January 2016 Location: Bristol Status: Offline Points: 109 |
![]() ![]() ![]() ![]() ![]() Posted: 07 July 2022 at 11:23am |
Is it best to seal a driver to the baffle with gasket tape or similar or are people just mounting the drivers directly most of the time?
doller ![]() Young Croc ![]() Joined: 19 July 2014 Location: japan Status: Offline Points: 509 |
I think that it is good practice. I do it. Costs very little. You can sometimes hear air escaping from around the driver. Badly sealed boxes will mess with your x max. As always could be wrong.
That make sense, thanks!
1ManSoundsystem ![]() Registered User ![]() Joined: 25 March 2019 Status: Offline Points: 29 |
hi, just a short hint from myself. ive seen people put the sealingtape on the speakergrill instead on the cabinet. dont do that. these speaker sealing tapes have very strong adhesive thats very hard to remove from the speaker, really nasty. rather put in on the wood of the box the speaker will be placed in.
teeth ![]() Registered User ![]() Joined: 05 July 2021 Status: Offline Points: 455 |
what about handles, speakon dishes, hardware etc. is it good to use gasket sealing tape such as this to seal them in?
cardiffdon ![]() Registered User ![]() ![]() Joined: 04 December 2008 Location: NewPort. Status: Offline Points: 480 |
yes
make sure you get a good seal around that shit dude.
cheers cardiffdon... anything i should go for in particular? silicon or somethin? i'll grab that foam gasket shit otherwise. thanks again
foam gasket stuff works fine for me.
cheers |
