Is it OK to run subs on different amps? |
Maze
Registered User Joined: 13 April 2014 Location: China Status: Offline Points: 179 |
Posted: 20 May 2021 at 3:21am |
I'm considering adding two more subs to my set up for six double 18s in total. To run two more subs I need one more sub amp. Would it be ok to use a different amp to run the two additinal subs? I know people say you shouldn't mix subs but how about amps?
imageoven
Old Croc Joined: 28 March 2007 Location: Scotland Status: Offline Points: 2186 |
I presume you mean a different type of amplifier, rather than an additional one the same type? Regardless, yes, it is fine. any half decent amplifier will behave imperceptably differently alongside another in this situation, provided they are both operating within their capabilities and level matched correctly. Any tonal differences will be minimal and will blend together. It will be easier to control (match levels) if they are the same type. Obviously if one hits its limits of capability before the other then there will be a difference (clipping / distorting earlier etc.) and you may not noticec this if the other more capable amplifier is masking it. Most people will aim to use the same type of amplifiers, it just makes everything easier.
shashnatiq
Registered User Joined: 20 December 2020 Status: Offline Points: 29 |
I have also wondered about this and I would like to ask if volume affects the quality of sound in some way.
What I mean is if his last 2 speakers that will be powered by a different amp, have slighly less/more volume than the others will this degrade sound quality in any way? |
Earplug
You are running 4 x double 18's off 1 amp? What amp? Are you running at 2 ohm/channel, or a 4 channel amp? In any case - different amps will have different voltage gains, slew rates, damping factors, etc. etc. - so always better to use the same make & model of amp. Were you going to do that anyway? In which case, no big deal. You may get slightly less power going into the other cabs and a slight difference in volume, but I'd say nothing really noticeable. It depends on the original amp you have. If you are going to use a completely different make and/or model - then you will most probably need to adjust your gain structure, etc. Again - it all depends on the amps, ie, we really need more information here. |
Earplug
As long as your system is "coherent", adding another amp and cabs should not degrade the sound quality. Even if the new cabs have slightly less SPL, as long as they match the others, the total SPL should sum and give you more overall volume. |
APW
Young Croc Joined: 13 November 2012 Location: Kent, UK Status: Online Points: 1173 |
Another thing to consider: If any of these amps have any form of digital processing onboard you may run into latency issues when mixing amp of different makes/models.... even the same amp model running different firmware versions could affect the amps latency. |
Maze
Thansk for the advice guys ... I got in contact with my gear supplier, but he has already stopped making the ampfliers he sold me before. I guess there's no choice but to go with a different one, or sell the one I have and buy two new ones if I can afford it. Actually, another reason I was curious about this is because I'm considering building some speakers with a setup consisting of sub, kicks and tops. I'd need one more amp for that too, but I was considering buying something second hand. Anyway I'm rambling now, I'm a dreamer |
Noyzmunky
Young Croc Joined: 10 June 2005 Location: United Kingdom Status: Offline Points: 1260 |
Sell what you have and buy a 4 channel amp capable of powering subs. Sorted.
otherwise you don't need to worry about any of it unless you start getting paid real money for doing it. 96% of people don't know the arse from the elbow of sound quality and wont care as long as it 'sounds good enough'. The rest will already have their own rig...lol. |
my name is Inigo Montoya...you killed my father, prepare to die!.
Earplug
Ok - corrected!! |
Maze
@Noyzmunky I have two amps right now, one for tops 4x1300W and one for subs 2x2400W. It's a turn-key system, but sounds pretty sweet to me :)
