Is it Posible to increase the total output |
djcrude
Registered User Joined: 16 April 2008 Location: United Kingdom Status: Offline Points: 250 |
Posted: 27 April 2009 at 2:32pm |
Hiya Guys,
Ive been looking around to invest in some new lights and found one which tickle my taste buds, which is the Skytronic LUX-LD01 MINI MOVING HEAD. Once looking at it on line i went to my local and saw it in action. It was all good! the moovement, the reaction to music, gobos, colour, The only problem i found was that it didnt have the total output i was looking for. . . . what im looking for is the out put similar to a 150 Discharge.
bescause i like the size and the light overall i was wondering if there is a way of increasing the output.
thnx
Crude
norty303
Buy a light with bigger output.
mk2_ginger_biscuit69
buy a head with a 150w discharge lamp then.....
H...
Young Croc Joined: 21 July 2008 Location: UK Status: Offline Points: 1164 |
I believe american DJ has basically the same but with a bigger LED source, not much bigger though!
Give LED profiles another 12 months and i reckon they would be able to beat a 150w HID - but for now on a budget have a look at an acme imove IS 200 HID
Don't worry F$cked up bigger gigs than this one...........
shagnasty
I am not saying it can't be done, because there is no such concept as "can't" but the chances of buying a ballast, PFC cap, ignitor, lamp holder, lamp and HT wiring for much less than the cost of the unit are slim. As for fitting it ...... The LEDs almost certainly use the same PSU as the logic so you will have to fit a smaller logic PSU in to get the ballast and PFC into the base and then wedge the lamp and ignitor into the head.....
Oh I did I mention optics? this will have next to none for a HMI you need a reflector, heatsheild and a coupla glass lenses.... Which brings us nice onto heat.... Loadsa heat, you need to retro-fit fans, probably quite chunky ones....
I am never one to try and stop someone doing a neat project but me thinks this may be more than a nights work....
Once all that is running you'll need a colour wheel, shutter, driver boards and new firmware, all easy really.
