Is Spotify high enough quality? |
Post Reply | Page 12> |
junoprobelaunch
Registered User Joined: 01 April 2018 Location: Devon Status: Offline Points: 298 |
Posted: 13 July 2018 at 8:13pm |
is Spotify high enough quality to play through a rig ? Would plug decks into a computer through USB then phono to xlr adapter from decks
APW
Young Croc Joined: 13 November 2012 Location: Kent, UK Status: Offline Points: 1173 |
Spotify ‘extreme quality’ is 320Kbs, so it’s not too bad; however you need a Spotify business account to do it legally: ……however this is €34.99 per location per month. You should also set your device so you can play tracks ‘off line’ just in case you lose your connection during your set. |
re-production
Registered User Joined: 16 February 2017 Location: Suffolk UK Status: Offline Points: 176 |
It depends on the rig, also seems to vary with the quality of the spotify track some rips seem to be better than others.
Tidal is a pretty good upgrade (lossless quality) for not much more.
toastyghost
Tidal’s HiFi tier is double the cost. Spotify is 320kbps OGG Vorbis when set to the highest level. I’m more curious how the decks to computer then phono to XLR bit works. Spotify is fine to play tunes from for background music between acts, or for a playlist party off a phone or laptop, but DJ tool it is not. I don’t even think it’s compatible with any of them. |
nickyburnell
You also need to think of the actual type of music when doing this or cheeky You Tube nonsense. Very good friend has a ton of 40s 50s and some 60''s on 128k. He does small scale older wedding and birthday stuff, never big. It's perfectly fine as it was so bad (in today's terms) when recorded There are a few exceptions which he is aware of, Beatles being one because of the bass guitar. Vera Lynn through a pair of Peaveys at 128 aint no different to the Vinyl :) Roughly late 60's/ 70's on he wont use anything under 320. Had no idea Spotify was 320 OGG, good to know, thanks
Edited by nickyburnell - 14 July 2018 at 9:07am |
U.Viktor
Young Croc Joined: 04 May 2010 Status: Offline Points: 716 |
Of course it is nowhere near to good quality.
I would say at least 192K Sample per second with 24bits resolution per channel is the minimum affordable 'professional grade' quality. Please do the math: 192KHZ * 24bits * 2channels = 9216K 1.15MB/s and this is WITHOUT ANY additional codes, checksums, etc!! So the required bandwidth would be at least 30X of the 320kbps.. And it is not any extreme 'high quality' just 192KS, 24bit resolution. Edited by U.Viktor - 14 July 2018 at 12:05pm |
dylan-penguinmedia
Old Croc Joined: 14 April 2011 Location: Brighton Status: Offline Points: 4576 |
But if you load the new Spotify for PKN app, and click on Elton John’s latest playlist, he actually jumps out the fans and sings accapella 6 inches from your face - THAT’s how high quality that is!
concept-10
Young Croc Joined: 17 May 2016 Status: Offline Points: 1292 |
gen0me
1.152MB per second You have high standards. I dont know anyone who could A/B 16bit and 24bit. It is calculated for .wav'es. Flac is lossless and it takes less MB.
Edited by gen0me - 14 July 2018 at 5:33pm |
djeddie
Is this to actually use Spotify as the "record collection" for the DJ? If so, I wouldn't bother. I've seen this go horribly wrong... embarrassingly wrong!
toastyghost
https://xiph.org/~xiphmont/demo/neil-young.html So no, you’re flat out wrong. Sorry. |
valve head777
Old Croc Joined: 27 July 2012 Location: East Sussex Status: Offline Points: 1780 |
Fire!!! tps://m.youtube.com/watch?v=en1uwIzI3SE#
