  New Posts New Posts RSS Feed - Ive made a mistake building my HD15s,
Timebomb View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Timebomb Quote  Post ReplyReply Direct Link To This Post Topic: Ive made a mistake building my HD15s,
    Posted: 07 May 2005 at 2:12pm
Ive mesured the distance from the point which the baffle meets the curved section to the back wall too short, i mesured it from the edge of the wood not from the back wall, so internally its 182mm instead of 200mm.  Is this going to make a big difference to the sound?  Its done now all the glue is dry so its going to be like this, but i was just wondering if this was big enough to make much difference to the sound?
Thanks.
James
tb_mike View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tb_mike Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2005 at 5:26am
Probably will make a slight difference,but is it audible? probably not.
If I understand correctly what you mean,youve made the horn slightly higher compression at the throat.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Timebomb Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2005 at 7:02pm
Yep i think youve got me, ive made the throat a little smaller and the rear chamber a little bigger.
When ive built the next paid ill compair them and see if i can tell a ifference.
Thanks Mike
James
Post Options Post Options   Thanks (0) Thanks(0)   Quote tb_mike Quote  Post ReplyReply Direct Link To This Post Posted: 11 May 2005 at 12:09am
since i ts only a wood thickness difference,its probably ~100cm^2 different throat area,which is about a 20% difference,wont change that much. The rear chamber will be slightly more compliant and not reduce excursion quite as much,but again not a problem probably
Cheers!
