🚨Jah tubbys 4way pre repair |
Post Reply | Page <123> |
dj jammin
Young Croc Joined: 10 April 2010 Location: southampton Status: Offline Points: 770 |
Just check the voltages inside to start with. If its way different from what i said then i will explain what to do next.. good luck..
Reverence Sound system
Youngculture89
Registered User Joined: 23 September 2018 Location: USA Status: Offline Points: 27 |
ok will get to it asap
Youngculture89
dj jammin
is that 15v ac after the transformer?
dj jammin
take a photo of the transformer / psu inside..
Youngculture89
Youngculture89
Youngculture89
no reading where the grey n Brown wire are located
studio45
That's not the transformer, that's the mains inlet. The transformer is the round thing to the right hand side. Those grey/brown and violet/blue wires are the power *input* to the transformer, so you need to find the other three wires that are the power *output*.
You should be able to measure a lower AC voltage on those wires. (Note that AC does *not* have polarity. So the earlier advice about looking for "+ and - 20v AC" is not quite right). The three wires are either end of the secondary winding, and a centre tap (halfway along the winding). So two of them will read ~24v AC, and the third will read ~12v AC (relative to either of the other two). Then you will be looking for a rectifier, this is either 4 diodes on a circuit board or a solid block with 4 terminals on it, near to a pair (or quad) of quite large capacitors. (round metal cans). Two of the terminals will be connected to the transformer output. At the other two, relative to ground (chassis ground) you should be able to measure *DC* voltage of about + and - 15 to 18 volts. You can also measure across the capacitor terminals if these are easier to find. If any of those measurements come up as zero, or much higher voltages than written above, there is a fault with the power supply. Meters going crazy, and audio circuits making strange "feedback", can *sometimes* be caused by either the + or - power rail not being present. All the audio circuitry needs both that + and - 15 volts present to work properly, so it's the first thing to check ;) |
imageoven
Old Croc Joined: 28 March 2007 Location: Scotland Status: Offline Points: 2186 |
While your in there I'd be putting some insulation tape on those mains input wires where they are connected to the socket (with the unit unplugged).
Youngculture89
Youngculture89
