  New Posts New Posts RSS Feed - 🚨Jah tubbys 4way pre repair
dj jammin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dj jammin Quote  Post ReplyReply Direct Link To This Post Posted: 05 April 2019 at 5:52pm
there we go.. two of the wires coming out the transformer will be joined together and this point is ground (0v) what voltage (ac) do you have between ground and each of the other 2 wires? Also under the 2 heatsinks there are voltage regulators, set your multi meter for dc.. what voltage are you getting between ground and each of the 3 pins on each reg.. note them down and come back with the results..
Reverence Sound system
King Simeon View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote King Simeon Quote  Post ReplyReply Direct Link To This Post Posted: 05 April 2019 at 6:08pm
BTW there should be two replies to your messages sent to JTS.
https://www.facebook.com/KingSimeonSound?ref=stream
https://soundcloud.com/king-simeon
Youngculture89 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Youngculture89 Quote  Post ReplyReply Direct Link To This Post Posted: 05 April 2019 at 6:23pm
ok
Post Options Post Options   Thanks (0) Thanks(0)   Quote King Simeon Quote  Post ReplyReply Direct Link To This Post Posted: 06 April 2019 at 10:24am
Just to update: Pre amp new to user, but dates back to 2015.
As with most items with a fault, best to contact manufacturer for guidance/advice.
I'm sure it will soon be restored so music can flow.
