JAMAICAN COOKIE CUTTER SOUNDSYSTEMS |
Post Reply | Page <1234 9> |
taurusty
Registered User Joined: 09 January 2007 Location: Jamaica Status: Offline Points: 473 |
Welcome to Sound Police, Reality! Glad the T 18's are finally waning in popularity...
RealitySound
Young Croc Joined: 01 February 2011 Location: Bermuda Status: Offline Points: 1137 |
Big up Taurusty. When did the mini double's become the sub of choice? Was it Stone Love with the 'Canadians'?
When you gonna send me some $$ mate ?
RealitySound
I see Bass Odyssey got some from Zann.
Jaro got some JBL Vertex line array tops too... Pics up somewhere. I'll put em up when I find em
taurusty
Yep. All of the current boxes are variations on Canadian/ Mini Scoop. Definitely an improvement over the T 18.
RiddimKid
Young Croc Joined: 22 October 2006 Location: United Kingdom Status: Offline Points: 847 |
Stonelove Template sound systems.
Anything Stonelove do the rest follow
JBK
Registered User Joined: 03 March 2016 Location: Besançon Status: Offline Points: 262 |
I always wondered where does the trend of putting mediums above the HF range, and / or compression drivers above tweeters come from?
Usually in the rest of the world the point source are stacked from low to high frequency, bottom to top I guess this is due to better copling of the drivers if they're close to one another. |
DMorison
Old Croc Joined: 14 March 2007 Location: Aberdeen Status: Offline Points: 1647 |
If they expect the audience to be very close to the stacks then HF at the very top could go over people's heads. Moving the HF down to the middle of the cab solves that. Just one particular set of compromises they've chosen.
JBK
Thanks for the answer, are you sure they do it specifically for this purpose or is it your guess at it?
Not only the jamaican sound systems have the audience close to the stacks, we often do too. In events I go in, when played at loud/war level usually you can still clearly hear the HF even if they're up your head and not tilted. I really wouldn't want those compression drivers and tweeters straight in my ears |
RiddimKid
My uncle once told me that the sound systems do it to keep noise inside the venue, thats the same reason why they use the t-18 type boxes so the bass fires down to the ground.
They believe if the horn and tweeters are in the middle the sound will not travel as far and there will be less police shut downs and complaints. However these days most events have permits and only run till 2am so sounds are going back to the normal way of straight double 18 boxes and horn/tweeters high in the air
Edited by RiddimKid - 28 March 2018 at 3:47pm |
KingGwarn
Registered User Joined: 19 March 2016 Location: Brighton Status: Offline Points: 193 |
From what I see in Sound Police, no one is rating that line array either! Pon left...
I wonder if it works like the Peter Morris 60 on a bigger scale/for bigger distances....where it sounds more like a single point source with the HF in middle....maybe they don't overlap frequencies in JA!
Soundman inna Brighton town
King Gwarn Sound System |
nickyburnell
In no way do those T18 keep anything indoors. I have tons of experience of them and if you do some looking on PSW there is a guy who does stadiums (half time singers etc) with 12 of them in USA. Having said that stacking them like they do does not work. In fact you may as well remove top row in my experience. Put the top ones upside down and in a block of four they chuck it as far as anything out there though. Nowt much below 50, unless eq is added in buckets, had some a few years ago for nostalgia and that roll down sub in modern music is just plain missing. Maybe we are all reading too much into the why, perhaps it's just fashion or hand me down advice? |
knet94
Old Croc Joined: 31 March 2008 Location: NW London Status: Offline Points: 1509 |
Scoops have been out of fashion a good while now. Check out these two threads. https://forum.speakerplans.com/no-one-in-jamaica-uses-scoops-anymore_topic63638_page1.html https://forum.speakerplans.com/scoops-in-jamaica_topic77199.html Shame most of the pics don't come up anymore. I've been in Jamaica for 5 months and have not seen a single scoop. |
