jbell SS15 |
mrchay ![]() Young Croc ![]() ![]() Joined: 29 September 2008 Status: Offline Points: 565 |
![]() ![]() ![]() ![]() ![]() Posted: 24 June 2011 at 12:51pm |
Does anyone have the plan for the Jbell SS15, or any experience with it?
JDCutta ![]() Registered User ![]() Joined: 24 June 2010 Location: North Lincs Status: Offline Points: 555 |
Heres the topic where the design originated, have a read through, lots of info there. Not built one, but read good things so far, most along the lines the of good output for the size/weight of the cab. |
rhuet99 ![]() Registered User ![]() Joined: 24 May 2009 Status: Offline Points: 105 |
I have built four of them. It's not a hard build. You REALLY can get a cab out of one 4' x 8' sheet. :) They sound good for their size. If you have a well equipped shop you can easily knock out a pair or two in a day. Best of luck if you build.
I have a poorly equipped garden, but hopefully that wont be a disaster. The driver I have to use is a fane 15xb. Anyone have a notion as to whether this will be a go-er? |
No, I doubt it has enough xmax to take much power. Use the 3015lf mate, I'm pretty sure theres enough details to simulate the design with fane 15xb on the link I posted you, or you could ask over on diyaudio.com - They will probably tell you to download horn responce and try yourself though ;) |
Among the threads there is a post or two with info on alternative cones for the SS15 box. I believe that the 3015LF has been the proven performer in all areas. The topic has been covered pretty extensively.
Good Luck. |
