  New Posts New Posts RSS Feed - jbl 2032H
jbl 2032H
discodave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote discodave Quote  Post ReplyReply Direct Link To This Post Topic: jbl 2032H
    Posted: 05 February 2012 at 5:25pm
iv got the building bug just dont know what iv got four may be six jbl 2032h drivers i was going to load then in some cubos but after listen to one in one desided not to know i dont realy know what design to go with there is not much in the way info on theres i managed to get this
2032H
FS /57
QTS 0.54 qms
 5.5 qes
 0.6 vas
 1331 eff
  4 pe
 300 xmas
 6.35 re
 4.2 le
 0.6 sd
 0.088
 bi 12.8
 mms 65
 flux 1
any body got any more info or iders much apprechated
_djk_ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote _djk_ Quote  Post ReplyReply Direct Link To This Post Posted: 06 February 2012 at 2:05pm
2032H
Fs= 57
Qts=0.54
Qms=5.5
Qes=0.6
Vas-133.1 L
No=4%
Pe=300W
x-max=6.35mm
Re=4.2Ω
Le=0.6mH
Sd= 0.088 M^2
Bl=12.8
mms=65g
Flux= 1.0T
A very inexpensive driver, I'm not sure what I would do with it. Let me think about it for a while.
Edited by _djk_ - 06 February 2012 at 2:09pm
djk
Post Options Post Options   Thanks (0) Thanks(0)   Quote _djk_ Quote  Post ReplyReply Direct Link To This Post Posted: 06 February 2012 at 2:26pm
Used in the 4655
http://www.jblpro.com/pub/install/4655.pdf
MR935
http://www.jblproservice.com/pdf/MR900%20Series/MR935.pdf
MR925
http://www.jblproservice.com/pdf/MR900%20Series/MR925.pdf
None of these have much output below 100hz at all, but they all scream above there (100dB/2.83V/1M).
You could easily get 50hz out of them in a TH design, probably around 103dB, but they would be large and not handle tremendous power.
http://www.jblpro.com/pub/mi/mr_broch.pdf
I would probably try and build MR935s with them, and use them with subs, or as side fills or a drum monitor. A friend of mine has the earlier version and uses them over an 18 as a drum fill.
http://www.jblproservice.com/pdf/MR800%20Series/MR835.pdf
Edited by _djk_ - 06 February 2012 at 2:34pm
djk
C-Audiofreak View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote C-Audiofreak Quote  Post ReplyReply Direct Link To This Post Posted: 13 January 2016 at 10:24am
Hi all as the jbl drivers seem hard to come by in the uk which eminence or 18sound driver would be a suitable alternative?
