JBL 615 |
Darren Ock
New Member Joined: 19 July 2022 Location: Adelaide Status: Offline Points: 2 |
Posted: 19 July 2022 at 9:04am |
If the JBL 615 are 1000 watts what does the 430 watts max means on the back of the speaker
njw
That'll be the power consumption from the mains.
Conanski
Old Croc Joined: 26 January 2006 Location: Ottawa, Canada Status: Offline Points: 2537 |
The appliance rating on the back panel is a maximum average draw that does not account for momentary peaks, and music is mostly momentary peaks so amplifier output power simply does not directly translate to AC mains draw.
But the other side of this story is that powered speakers... especially down at the consumer level... advertise peak amplifier output not the continuous average.
Edited by Conanski - 19 July 2022 at 4:27pm |
Line Array
Registered User Joined: 19 March 2022 Location: New Jersey, USA Status: Offline Points: 83 |
430W is for the purposes of sizing power cords, circuit breakers and so on.
1000W is not real power. It says right on the product page that it's 500W continuous. 500W is still more than 430W and that is fine for reasons others explained. 430W is SINEWAVE power while 500W is MUSIC power. Music is less energy dense than sinewaves so this is completely normal. Music power can be up to about 8 times higher than sinewave power but this would assume 100% efficient amplifier with uncompressed program and no clipping. ultimately both the 500W figure and the 430W figures should be of interest to you. the 1000W figure is just marketing nonsense. if this was a high-end fully-professional speaker ( as opposed to entry level / prosumer / amateur / PA speaker ) you would not see that 1000W figure at all - only the 500W figure. the cheaper the speakers the more the power figures are inflated because the customer for the cheaper speaker is less knowledgeable. that said JBL is a reputable company so they will not lie outright - only BEND the truth a little bit. this is why you get both the 1000W and 500W figures. i think EON are good for the price as long as you use a high pass filter and a subwoofer. can't comment on reliability of the amplifier module but you might be able to find replacements as it's a popular speaker.
Edited by Line Array - 21 July 2022 at 2:32am |
best place on the internet >>>
https://dissidentsound.discoursehosting.net |
partya
Registered User Joined: 06 September 2013 Location: New Zealand Status: Offline Points: 105 |
Thanks(1)
Here in NZ, the replacement parts supplier ran out of spare amplifier modules a long while ago... The local repairman told me that they the EON 600 series is the 'most unreliable series JBL have produced in a while'. Not cheap here either.....
Turn it up! Turn what up?
