  New Posts New Posts RSS Feed - JBL MS112 replacement drivers
simba View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote simba Quote  Post ReplyReply Direct Link To This Post Topic: JBL MS112 replacement drivers
    Posted: 05 June 2018 at 2:38pm
Hi All,
Any suggestions for good alternatives to the M222-8  12" drivers in the JBL MS112?
I have 2 with blown drivers, compression drivers are fine.
Thanks!
Hemisphere View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hemisphere Quote  Post ReplyReply Direct Link To This Post Posted: 05 June 2018 at 2:51pm
M222-8 T/s parameters (thanks to _djk_ for the link! http://www.jblproservice.com/pdf/Thiele%20Small%20Parameters/Theile%20Parameters.pdf)
FS   QTS   QMS  QES   VAS  EFF    PE    XMAX   RE   LE     SD     BL    MMS FLUX
71   0.48  3.6    0.55   41.9 2.62   300  6.35    4.2   0.43 0.053 12.8 48     1
There's a starting point. Finding drivers with near to these T/s parameters won't be easy, but work out the box and port dimensions (doesn't need to be precise, just a ballpark figure), model it, model alternative candidates and compare plots.
https://www.beyma.com/getpdf.php?pid=12MCS500
Beyma 12MCS500 may be a good option. Fairly similar on several counts.
Edited by Hemisphere - 05 June 2018 at 3:05pm
Phase 1: Post on Speakerplans
Phase 2: ?????
Phase 3: Profit!
Post Options Post Options   Thanks (0) Thanks(0)   Quote simba Quote  Post ReplyReply Direct Link To This Post Posted: 05 June 2018 at 4:39pm
Many Thanks for the reply Hemisphere, thats great info.
This page was generated in 3.750 seconds.
