  New Posts New Posts RSS Feed - JBL SRX835P 15" Three-Way
trev1998 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote trev1998 Quote  Post ReplyReply Direct Link To This Post Topic: JBL SRX835P 15" Three-Way
    Posted: 30 April 2019 at 7:39pm
I am looking for accurate plans for the JBL SRX835p . I've falling in love with the design and been looking for ages ,are there any plans flowing around??
djeddie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote djeddie Quote  Post ReplyReply Direct Link To This Post Posted: 30 April 2019 at 9:13pm
It's a current design so you won't be able to get them here.
Plus, why? Do you have the drivers it uses? Do you have the horns it uses? Do you have the Crown amp-pack that's stuck in the back? Didn't think so.
Post Options Post Options   Thanks (0) Thanks(0)   Quote toastyghost Quote  Post ReplyReply Direct Link To This Post Posted: 30 April 2019 at 10:17pm
Not to mention that it is literally a basic reflex box with proprietary horns and amp/DSP module stuffed in it. It's probably cheaper to buy one than do all the work getting a custom mould to clone it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote trev1998 Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2019 at 7:06pm
i just like the design,will be using all different drivers and it will be
passive instead of a built in amp
DMorison View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMorison Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2019 at 11:19am
Then it won't be an SRX835P in any meaningful way, so there's no point whatsoever asking for plans for that box in the first place!
JonB67 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JonB67 Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2019 at 11:38am
If you're using different drivers take the idea and aesthetic as inspiration and design your own. There's enough info in the archive to get you most of the way there and then people will help you polish the details. Its a lot to read and learn if you've never done it before. Well worth it though if you are interested.
Unfortunately most people posting for plans just want a free lunch rather than an r&d project.LOL
