  New Posts New Posts RSS Feed - JBL VS125HS anything like HD15?
serioussound View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote serioussound Quote  Post ReplyReply Direct Link To This Post Topic: JBL VS125HS anything like HD15?
    Posted: 13 June 2020 at 6:54pm
I have some JBL VS125HS empty cabs.
Would these be any good as kickbins kind of like HD15?
On the shelf I have JBL 2226H and RCF L15P540 to load them with.
Here are specs:
Edited by serioussound - 13 June 2020 at 6:59pm
VECTORDJ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote VECTORDJ Quote  Post ReplyReply Direct Link To This Post Posted: 13 June 2020 at 9:35pm
Looks to be a very short band pass horn. Should be a good kick bin. Try it with both + as hot and - as hot to hear diff in system sound. VECTORSONICS
Post Options Post Options   Thanks (0) Thanks(0)   Quote serioussound Quote  Post ReplyReply Direct Link To This Post Posted: 04 July 2020 at 11:30pm
Im all new to kick bins what would be some classic crossover points to start with for a 4 way mono rig with:
2 Dual 18” BR subs loaded with JBL 2241H.
2 Dual 15” Kickbins JBL VS125HS loaded with 2226H.
2 Standard midtops 12” or 15” + 2”.
Its mainly the crossover between sub and kick and between kick and midtops I need help with.
Also will the 2 dual 18 balance good with the 2 dual 15” kickbins?
My plan is to lay BR 218 down. Then lay Dual 15” kickbin over that and then the midtops on top. Maybe using 4 midtops when larger coverings needed.
shaun1264 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote shaun1264 Quote  Post ReplyReply Direct Link To This Post Posted: 05 July 2020 at 9:24am
I used to have a pair of VS125HS.  They were loaded with 2226’s.  High sensitivity and good fast kick. Don’t expect much below 50hz.
Conanski View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Conanski Quote  Post ReplyReply Direct Link To This Post Posted: 05 July 2020 at 6:34pm
So you're good with figuring out time alignment then? Without this the kicks will mess up everything above and below them.
Post Options Post Options   Thanks (0) Thanks(0)   Quote serioussound Quote  Post ReplyReply Direct Link To This Post Posted: 05 July 2020 at 6:36pm
No Cry
Digbethdave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Digbethdave Quote  Post ReplyReply Direct Link To This Post Posted: 05 July 2020 at 7:11pm
No Cry
Chuck some drivers in, and have a go.
Dutchman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dutchman Quote  Post ReplyReply Direct Link To This Post Posted: 05 July 2020 at 8:13pm
What I would try,
subs 35 to 80
kicks 70-80 to 150
then let the tops play from 150hz up Smile
We need more SPL!
teeth View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote teeth Quote  Post ReplyReply Direct Link To This Post Posted: 15 November 2023 at 9:17pm
i'm looking to get 4x of these. not a bad price with whatever the original drivers are.
does anyone have more to add? know what the OG drivers are? :]
