JBL VS125HS anything like HD15? |
serioussound ![]() Registered User ![]() Joined: 01 December 2013 Status: Offline Points: 443 |
![]() ![]() ![]() ![]() ![]() Posted: 13 June 2020 at 6:54pm |
I have some JBL VS125HS empty cabs.
Would these be any good as kickbins kind of like HD15? On the shelf I have JBL 2226H and RCF L15P540 to load them with. Here are specs: ![]() Edited by serioussound - 13 June 2020 at 6:59pm |
VECTORDJ ![]() Registered User ![]() ![]() Joined: 11 June 2006 Location: United States Status: Offline Points: 496 |
Looks to be a very short band pass horn. Should be a good kick bin. Try it with both + as hot and - as hot to hear diff in system sound. VECTORSONICS
Im all new to kick bins what would be some classic crossover points to start with for a 4 way mono rig with:
2 Dual 18” BR subs loaded with JBL 2241H. 2 Dual 15” Kickbins JBL VS125HS loaded with 2226H. 2 Standard midtops 12” or 15” + 2”. Its mainly the crossover between sub and kick and between kick and midtops I need help with. Also will the 2 dual 18 balance good with the 2 dual 15” kickbins? My plan is to lay BR 218 down. Then lay Dual 15” kickbin over that and then the midtops on top. Maybe using 4 midtops when larger coverings needed. |
shaun1264 ![]() Registered User ![]() ![]() Joined: 06 September 2013 Location: Surrey Status: Offline Points: 260 |
I used to have a pair of VS125HS. They were loaded with 2226’s. High sensitivity and good fast kick. Don’t expect much below 50hz.
Conanski ![]() Old Croc ![]() ![]() Joined: 26 January 2006 Location: Canada Status: Offline Points: 2467 |
No
Digbethdave ![]() Registered User ![]() ![]() Joined: 16 November 2018 Status: Offline Points: 405 |
Chuck some drivers in, and have a go.
Dutchman ![]() Registered User ![]() ![]() Joined: 23 March 2013 Location: GENT Status: Offline Points: 365 |
What I would try, kicks 70-80 to 150 then let the tops play from 150hz up
We need more SPL!
teeth ![]() Young Croc ![]() Joined: 05 July 2021 Status: Offline Points: 506 |
i'm looking to get 4x of these. not a bad price with whatever the original drivers are. does anyone have more to add? know what the OG drivers are? :] |
