K30 Amplifier On The Bench |
Page 123 4> |
Elliot Thompson ![]() Old Croc ![]() ![]() Joined: 02 April 2004 Location: United States Status: Offline Points: 5054 |
![]() ![]() ![]() ![]() ![]() Posted: 14 May 2021 at 1:21am |
K30 AMPLIFIER BENCH RESULTS
Line Voltage During Test 250 volts, 60 Hz
Metering Used Amprobe Clamp Meter Clarke-Hess Power Analyser Hewlett Packard Distortion Analyzer Klein Tools Clamp Meter
Amplifier Temperature During Tests Starting Temperature: 39 Celsius (102.2 F) Ending Temperature: 45 Celsius (113.0 F)* Room Temperature: 17.7 Celsius (63.86 F)
Note: Room Temperature was measured with a Klein Tools Dual Laser Infrared Thermometer
* Excluding Longevity Test
Amplifier Thermal Status (From The Manual) Normal: 32 – 69.0 Celsius Overheat Warning: 69.1 – 75.0 Celsius Thermal Protection: 75.1 Celsius
Burst Ratings (Keele Tone-Burst Test) 50 Hz, 63 Hz & 80 Hz
https://www.prosoundtraining.com/2015/10/13/pats-blog-keele-tone-burst-test/
Frequencies: 50 Hz, 63 Hz, 80 Hz Wattage: 9227.52, 9467.29, 9467.29 Load: 4 ohms
Note: Each Output Channel, under a 4-ohm load, registered anywhere from 48.03 – 48.65 amps in rush current (10 pulses per frequency) undergoing the Keele Tone-Burst test. The amplifier completed the test with no issues. The burst were made using the left channel of the audio files. They are available free to download (Link Above) in which, you can get an idea of the type of pulses the amplifier had to endure during the test.
Line Source Current Consumption Under Burst Ratings Using A 4-Ohm Load
250-volt Line Source: 37.86 amperes (Single Channel) Measured
240-volt Line Source: 39.45 amperes (Single Channel) Estimate 240-volt Line Source: 78.9 amperes (Both Channels Driven) Estimate
120-volt Line Source: 78.9 amperes (Single Channel) Estimate 120-volt Line Source: 157.8 amperes (Both Channels Driven) Estimate
Continuous Sinusoidal Wave
Frequency: 59.89 Hz Wattage: 3398.89 Load: 4 ohms THD: 1.0%
Note: The amplifier can offer this kind of wattage continuously with no significant drops in output power and, no ramping into protect mode. The clip lights (Yellow Indicators) are not on @ 1.0% THD. The amplifier does reduce it's wattage slightly once the clip lights are present. The output power is reduced to 3317.76 watts. The Clip Limiter may be the culprit as, it is factory default in an ON position. Once the Clip Limiter is turned off, the slight drop in wattage is not present. Please bear in mind, moving from 3398.89 watts to 3317.76 watts only yields a -0.10 dB loss.
Dynamic Headroom 4-ohm Load
From 3398.89 watts to 9467.29* watts: +4.45 dB
* * Highest Measured Peak Wattage rating based on an in-rush current of 48.65 amps using a 4-ohm resistive load.
Crest Factor
Frequency: 59.89 Hz Wattage: 4806.03*
Load: 4 ohms * Manufactures advertised specifications is 5000 watts per channel @ 4 ohms. 5000 watts vs 4806 watts offers a mere -0.17 dB loss
Crest Factor 100 Hz – 5 Hz
100 Hz: 4806.03 watts @ 4 ohms
90 Hz: 4806.03 watts @ 4 ohms
80 Hz: 4806.03 watts @ 4 ohms
70 Hz: 4806.03 watts @ 4 ohms
60 Hz: 4806.03 watts @ 4 ohms
50 Hz: 4806.03 watts @ 4 ohms
40 Hz: 4806.03 watts @ 4 ohms
30 Hz: 4806.03 watts @ 4 ohms
20 Hz: 4806.03 watts @ 4 ohms
10 Hz: 2809.08 watts @ 4 ohms
5 Hz: 1328.34 watts @ 4 ohms
LONGEVITY TEST
Starting Temperature: 45 Celsius Ending Temperature: 55 Celsius Frequency: 40.04 Hz Type: Sinusoidal Wave Duration: 2:52.049 (Two Minutes, Fifty-two Seconds) Load: 4 ohms Starting Voltage: 104.4 volts (2724.84 watts) Ending Voltage: 104.4 volts (2724.84 watts) Amperage From 4-ohm Load: 26.10 A Amperage From 250-volt Line Source: 10.89 A
The amplifier maintained a constant output voltage from start to finish. The only noticeable difference from the amplifier was an increase in Celsius and, Fan Speed. The amplifier was -0.96 dB away from clipping (1.0% THD) playing a 40 Hz sinusoidal wave continuously for nearly three minutes.
Note: Test was halted due to the 4-ohm resistor. The 4-ohm resistor began delivering a heavy dose of smoke. The objective of this test was to determine how long the amplifier would maintain it's output voltage under a 4 ohm load before ramping into protection or reducing it's output (Whichever came first). Since the resistor began to give off heavy smoke, the risk of an electrical fire was too high. The test was halted and further measurements were put off to a later date. The amplifier's thermal rating (55 Celsius) once the test was halted, is still within it's normal thermal status. The K30's overheating warning begins at 69.1 Celsius.
Audible Difference In dB Output
3398.89 watts @ 4 ohms versus 2724.84 watts @ 4 ohms: 0.96 dB differential Best Regards, Edited by Elliot Thompson - 14 May 2021 at 1:26am |
kipman725 ![]() Registered User ![]() Joined: 02 September 2020 Location: Warrington Status: Offline Points: 211 |
Thanks for posting these measurements. It looks quite close to a Powersoft K10/K20 in output. Particularity impressive are that it can sustain 3kW per channel sine wave. Does anyone know what the sine wave output power of a K20 is? Also what is the cost of a Admark K30?
I have no idea how much the Admark cost.
The amplifier I purchased was made by Morin. Morin is an Original Design/Equipment Manufacturer (ODM/OEM). If you wanted to have "kipman725" Logo on the faceplate, Morin will have it done for you. There is no minimum quantity to have it done. If you are buying quantity, you could requests having the faceplate modified to your aesthetics.
The K30 has been fairly popular on the underground scene since 2019 in the United States. As for price, just go to Alibaba and type K30 Amplifier. Although the price should be the same, the total cost may differ with shipping due to your location.
Best Regards,
Edited by Elliot Thompson - 14 May 2021 at 8:28pm |
doller ![]() Registered User ![]() Joined: 19 July 2014 Location: japan Status: Offline Points: 495 |
Thank you for your effort Elliot. Sounds like you are happy with this amp. Big question long term reliability. I realize it must be hard for you to comment only having the amp for a short time. Any impressions thoughts on the subject?
Any idea of 2ohm load performance?
I've only had the amplifier for a week. You would need to contact me within a year if you would like my user experience in terms of reliability using the K30 Amplifier. I will say this. In the United States, the users are not complaining about the K30 failing. Are you willing to feed the amplifier at least 200-volts A.C. (Twice Japan's 100-volt standard) to take full advantage on what the amplifier can offer? Estimated AC Current based on the Burst Wattage Rating (18,000 watts) both channels driven (4-ohms per channel) would be around 185 amperes on a 100-volt line source. Best Regards,
Edited by Elliot Thompson - 15 May 2021 at 3:46pm |
All testing on my side are halted until the new resistors arrives. Best Regards, |
I doubt that I will need anything like that kind of current draw. Doubt that I could get it anyway in the countryside. 100v is hard work. That is one reason I have the Yamaha px10's I can take them pretty much anywhere they will do the job without tripping. Won't run hogs I know. But they work for what I want. I do have pl4 when I can use them. I seen to many sound men with ampere clamps running around sweating.
So, how does it sound? Are they a direct rip off of a powersoft or something else or has there been some design work done by the maker?
Earplug ![]() Old Croc ![]() Joined: 03 January 2012 Location: Europe Status: Offline Points: 6917 |
Yes - maybe post some detailed internal pics... ![]() |
The Power Factor Correction makes the K30 consume a lot of current if you were going to use it on 120 volts while idling. I cannot imagine what the K30 would do on 100 volts. When I measured the K 30's idle current on 120 volts (20-A Circuit), the current was fluctuating from 0.65 Amps to 11.46 Amps. That is without a load and, no input signal. The cycling continues until you turn off the amplifier.
The start up time is also longer with less voltage at the amplifier's disposal. On 250 volts, the amplifier stabilises in 2-3 seconds from a cold start. On 120 volts, the amplifier can take anywhere from 7 – 9 seconds to stabilise using a household 20-A Circuit.
At the moment, the only amplifier I have compared the K30 to is QSC (Class H). I bought the K30 solely for low-midrange since, I do not need another Bass Amplifier.
Matching the output voltage of the QSC and K30, the QSC offers a more richer tone in the low mid section whereas, the K30 supersedes the QSC on dynamic Attack. With both amplifier's output voltage matched using a 55 Hz sine wave and, were evaluated -20 dB from clipping, the K30 shines over the QSC from a percussion perspective. However, from a male vocal standpoint, the QSC sounds more prominent than the K30. Since the K30 will be used with the QSC amplifiers, it's not a matter of picking one over the other. However, if I had to take a choice between the two, I would lean towards the K30 and, make minor EQ adjustments. I only own QSC Class H amplifiers so, my thoughts may have been different if I was comparing QSC Class D to the K30.
I have not compared the K30 to Crown's Class I and Peavey's Class D amplifiers (Those are the modern amplifiers I use for Bass) at the moment. If bass is the main reason you are considering the K30, I can give you an analysis from a tonal standpoint where the K30 stands against the Crown Class I, and Peavey Class D amplifiers by the end of May. If you are using old iron, I can compare the tonal characteristics to my Crown 5000vz amplifiers.
Best Regards,
Edited by Elliot Thompson - 16 May 2021 at 11:15am |
I will post pics in the usual spot by the end of next week. Best Regards,
MarjanM ![]() Old Croc ![]() ![]() Joined: 10 February 2005 Location: Macedonia Status: Offline Points: 7695 |
So Elliot, can you share you tonal experience of the amp now?
I am really interested in how it sound. You have the 5000vz so that should be a nice amp to compare the sound with. TY.
Page 123 4> |
