  New Posts New Posts RSS Feed - Keeping Fane XB alive in this large chamber mini?
sarsen1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote sarsen1 Quote  Post ReplyReply Direct Link To This Post Topic: Keeping Fane XB alive in this large chamber mini?
    Posted: 22 February 2021 at 11:37am
I picked up some mystery mini scoops from ebay and some bargain fane XBs from gumtree for a low budget lockdown project.
From what I can gather, the mini's are to the modified MS-18 mk1 (MS-18 ..Mini Scooper - Speakerplans.com Forums - Page 12) plans with double 370mm rear baffle as below. However, the chamber looks to me like it is a bit big for the XB...
Should I try to put another 18mm rear baffle on to reduce the chamber size to 246mm? Or just run 38hzish hpf and not push it? Or any other ideas? (swapping cabs/drivers for more hardy Void/PD drivers not an option as keeping the costs low as possible).
I will be powering with berry inuke 6000 and have an ultradrive at my disposal. Music will be mostly roots/dub/80s dancehall but also other various styles.
Any advice on keeping less than ideal drivers alive in large chamber scoops would be greatly welcomed!
VECTORDJ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote VECTORDJ Quote  Post ReplyReply Direct Link To This Post Posted: 22 February 2021 at 12:06pm
For the best Bass add more subs.....8 Mini Scoops run at 600 watts each will sound better then 2 run at insane crazy input levels. All woofers will fail if driven hard enough. Setting the Hi Pass filter higher will reduce cone flapping but of course will reduce deep bass to Your ears. In large chamber scoops one can always add blocks of wood or some other solid to reduce the chamber size to hear the diff. Scoops are Cool..............
levyte357- View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote levyte357- Quote  Post ReplyReply Direct Link To This Post Posted: 22 February 2021 at 12:17pm
Leave Mini Scoop as is.
Sell the Fane 18XBs,
Get used PD1850 or Void V18-1000.
Will sound much better, and handle your music type, as I'm sure you'll be using a pre-amp.
Post Options Post Options   Thanks (0) Thanks(0)   Quote sarsen1 Quote  Post ReplyReply Direct Link To This Post Posted: 22 February 2021 at 12:59pm
Yes for sure more would be better, this design is nice and simple so if I am happy with the sound and don't get cone over-excursion issues I will knock up some more.
I knew this was coming, will keep an eye out for deals 2nd hand drivers and leave as is for the time being. No pre-amp yet but some kind of 1u unit with parametric EQs and killswitches to go into the ultradrive for limiters/alignment is the plan.
Thanks for the replies
Post Options Post Options   Thanks (0) Thanks(0)   Quote levyte357- Quote  Post ReplyReply Direct Link To This Post Posted: 22 February 2021 at 2:44pm
I am saving you money.
Fane 18XBs sound absolutely lovely in the right Scoops, right up until you get carried away, with your favorite Johnny Osbourne tune, and the Scoop go quiet... LOL
Post Options Post Options   Thanks (0) Thanks(0)   Quote sarsen1 Quote  Post ReplyReply Direct Link To This Post Posted: 22 February 2021 at 3:43pm
hahaha yes this is what I fear. Ready or not, here I come........ blown drivers
Meat Substitute View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Meat Substitute Quote  Post ReplyReply Direct Link To This Post Posted: 22 February 2021 at 3:57pm
...but in the meantime, you can wad the hell out of the chamber as a low cost stop gap. It won't make them bullet proof and you'll need to be careful you don't block the vents as well as with the power but it might get you a little bit more.
Post Options Post Options   Thanks (0) Thanks(0)   Quote sarsen1 Quote  Post ReplyReply Direct Link To This Post Posted: 22 February 2021 at 4:20pm
Thanks for the tip, hopefully then with plenty of wadding and conservative hpf/limiting/eq I should be able to get a nice sound out of them while I keep an eye out for deals on v18-1000/pd1850.
imageoven View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote imageoven Quote  Post ReplyReply Direct Link To This Post Posted: 22 February 2021 at 5:32pm
Cut the bottom 400mm off the cab and it would be about the right size for a reflex....
infrasound View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote infrasound Quote  Post ReplyReply Direct Link To This Post Posted: 22 February 2021 at 5:58pm
https://www.ebay.co.uk/sch/i.html?_from=R40&_trksid=p2380057.m570.l1313&_nkw=blue+model+foam&_sacat=0
Use modelling foam or polystyrene sheets and glue / nailgun to reduce volume if you want to
Cheap as chips and easy to undo later on
Post Options Post Options   Thanks (0) Thanks(0)   Quote sarsen1 Quote  Post ReplyReply Direct Link To This Post Posted: 22 February 2021 at 7:39pm
Got a few tiles of acoustic foam left over from treating a studio room so might stick that in there and see how it goes!
