  New Posts New Posts RSS Feed - Kick bass 2pi or 4pi
Augusts View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Augusts Quote  Post ReplyReply Direct Link To This Post Topic: Kick bass 2pi or 4pi
    Posted: 22 August 2020 at 10:10pm
Hello community
How would you simulate a kick bass enclosure, that would be stacked over the subs?
This is for hornresp, 2pi or 4pi?  My logic says 4pi as the boxes are not sitting on ground but the HD15 simulation for example is done in 2pi.
Thanks
August
Fracture_clinic View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fracture_clinic Quote  Post ReplyReply Direct Link To This Post Posted: 23 August 2020 at 4:47am
4pi if they're up on subs. How high are they going to be out of curioisity?
citizensc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote citizensc Quote  Post ReplyReply Direct Link To This Post Posted: 23 August 2020 at 11:44am
I would sim both and try draw my conclusions from that. Neither is a perfect representation of the real world.
It isnt 2pi because its not sitting on the ground, it isn't 4pi unless its floating in the air, the speakers you stack it on top of will have a non zero effect.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Augusts Quote  Post ReplyReply Direct Link To This Post Posted: 24 August 2020 at 11:18am
Thanks for your replies!
Subs are 82cm if one vertically or 120cm if two horizontally, those are 21"
DMorison View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMorison Quote  Post ReplyReply Direct Link To This Post Posted: 24 August 2020 at 12:59pm
I'd rather model in 4pi & find I have a little extra in the real world than get my hopes up based on a 2pi model and then be disappointed at having to EQ back in a bunch of extra LF, using up power & excursion on the process.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Augusts Quote  Post ReplyReply Direct Link To This Post Posted: 24 August 2020 at 1:10pm
I find that 4pi is more spiky than 2pi thats why I wanted to clarify this but I would still have to go for less spiky anyway
