  New Posts New Posts RSS Feed - Kick/Bass Bin-cabinet for 90-360hz
 Post Reply Post Reply Page  <1234 6>
corell View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote corell Quote  Post ReplyReply Direct Link To This Post Posted: 13 October 2017 at 1:28pm
Originally posted by Mikkel Mikkel wrote:
Originally posted by corell corell wrote:
MKB will never play to 380 Hz, even MKH struggles to do so.
good to know. I was only going off the frequency response graphs on the webpage.
SPL wise, they play to 500-600 Hz more or less flat. But they sound shit above a certain frequency, i would say 350 Hz is accetable for the MKH with careful EQing, 300 Hz without.
SouthwestCNC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SouthwestCNC Quote  Post ReplyReply Direct Link To This Post Posted: 13 October 2017 at 2:29pm
Originally posted by KMB KMB wrote:
well i have a 4 way pre amp with kick 92-360hz..
Not sure what shipping would be to Belgium. But the rb212 plays 90-370hz flat. 109db@1w1m
Edited by SouthwestCNC - 13 October 2017 at 2:32pm
Brutus View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brutus Quote  Post ReplyReply Direct Link To This Post Posted: 13 October 2017 at 3:16pm
jbl 4512 or jbl 4560
KMB View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KMB Quote  Post ReplyReply Direct Link To This Post Posted: 15 October 2017 at 11:14am
Do you have a site or plans for the rb212 because i cant find anything about it on the net. thanks
Timebomb View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Timebomb Quote  Post ReplyReply Direct Link To This Post Posted: 15 October 2017 at 11:35am
The RB212 is a cabinet i designed several years back, ive licensed it to Southwest CNC now.  No free plans im afraid sorry.
Keen View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Keen Quote  Post ReplyReply Direct Link To This Post Posted: 05 November 2017 at 1:10pm
109db@1w1m
that will be 2PI, kicks are 4PI, so more like 104db; Unless the midbass stack is on the ground, which is feasable.
Post Options Post Options   Thanks (0) Thanks(0)   Quote RoadRunnersDust Quote  Post ReplyReply Direct Link To This Post Posted: 06 November 2017 at 6:13am
109db@1w1m
According to the theory, at 360Hz the kicks could be half a meter off the ground and still be 2Pi...
I don't reckon that on-top of a couple of subs would constitute "Free Air" LOL
Post Options Post Options   Thanks (0) Thanks(0)   Quote SouthwestCNC Quote  Post ReplyReply Direct Link To This Post Posted: 09 November 2017 at 9:47am
109db is a half space measurement but yeah the cabs unlikely to be used in free space so it always going to be somewhere between the two and subject to change depending on how you are stacking it and whether it is coupling with other cabs or not.
Edited by SouthwestCNC - 09 November 2017 at 11:23am
levyte357- View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote levyte357- Quote  Post ReplyReply Direct Link To This Post Posted: 09 November 2017 at 4:45pm
For Reggae/Dub and that Pre-Amp, 2x15" Reflex, for going above 2x 18" Scoops, is the best sound you will get.
Just use very sensitive drivers, OR drivers that have really high power handling (NOT SUB 15s).
In Reggae world, 90-400hz, is almost more important, than the sub.
And yes, some vocals go down to 90hz.
Post Options Post Options   Thanks (0) Thanks(0)   Quote RoadRunnersDust Quote  Post ReplyReply Direct Link To This Post Posted: 09 November 2017 at 4:57pm
Originally posted by efinque efinque wrote:
This may sound a bit dumb but 360Hz is pretty high for a kick.
Let's take for example drum'n'bass where you'd mix subs below 100Hz, kick on top of that and the snare peaking at around 250Hz where it has the most "body". The information that cuts through the mix and makes it sound like a snare is located higher on the frequency spectrum (5-7kHz) which may sound high at first.
EDIT : Some EDM/dnb producers add a hi hat on top of the kick to add some spice to it.
EDIT 2 : The percussive, groovy stuff of a bassline is located in the same frequency range as most of the drum section but the interesting nuances are above 250Hz.
EDIT 3 : I wrote a half-a**ed book which has some stuff related to the subject
Could you contain your BS to your dancestack post?
Post Options Post Options   Thanks (0) Thanks(0)   Quote corell Quote  Post ReplyReply Direct Link To This Post Posted: 09 November 2017 at 5:02pm
15NDL88, MB15N405, 15ND930 or something alike would be great.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SouthwestCNC Quote  Post ReplyReply Direct Link To This Post Posted: 09 November 2017 at 6:58pm
I thought the point of a mid kick with high range was to be part of a 4 or even 3 way system, less comb filtering, closer to point source. In an ideal world one way.. how nice that would sound.
