Kick/Bass Bin-cabinet for 90-360hz |
Post Reply | Page <1 23456> |
smitske96
Young Croc Joined: 16 February 2016 Location: The Netherlands Status: Offline Points: 1092 |
For almost everything is a solution. But with that new solution there are new problems
SouthwestCNC
From what i gather FIR is used by various filters. Which one are we talking about here?. I know RePhase uses FIR and that requires REW loop back time alignment to be in place to work. Are you saying that rephase then messes with the alignment?
KMB
Registered User Joined: 02 October 2017 Location: Belgium (dutch) Status: Offline Points: 34 |
would this BR030 bin be good?
it plays from 20-500 hz so for my bass bin 90-360 would play good no? This bin also exists in 15" version, same frequency range.
Hemisphere
Just because a spec sheet says 20-500Hz doesn't mean it can do 20-500Hz.
I mean obviously it can't do 20Hz (Elliot Thompson may disagree), and since they're happy to claim it can we could hazard a guess it won't really be able to do 500Hz either. It will play to 360Hz of course, and it might even sound good that high, but as a rule of thumb you don't want to be playing an 18" up there if you can avoid it. 15 would be more appropriate.
KMB
Anther question:
If I glue and screw my scoop together at 2-3pm, would it be ok to load the scoop with the driver around 8-9pm and play it out loud?
So with other words, how long should I wait untill the woodconstruction is good (dry)? Thanks! |
SouthwestCNC
depends on the glue and if its rebated with tight joints it can slow curing. best leaving it 24hours in most cases really.
mauisurf
Registered User Joined: 12 December 2017 Status: Offline Points: 16 |
Efinque... HALP! I started a thread and your are required for all the ansewrs supposedley.
KMB
Hi guys,
Thanks for helping Can you tell me which type of screws i need to mount my 18" woofer into my mogale superscooper? Thanks! |
parabox
Registered User Joined: 03 February 2017 Status: Offline Points: 20 |
So I have been talking to some cats on the east coast of the us about some very impressive planer kicks that to be honest are just plain hot I personally dropped some coin for plans and I'm very excited to. Throw em together
Futur3boy
New Member Joined: 18 September 2018 Location: Bristol Status: Offline Points: 8 |
Hi, Any idea where can I get rb212's made these days? Also can you tell me the drivers they take? Looking to cover 90 to about 250ish and seems like this is a good option. Also do you know the dimensions of the box? Thanks for any info. I got in touch with southwest cnc, but their site is down and I got no response via facebook.
RoadRunnersDust
Young Croc Joined: 03 December 2013 Location: United Kingdom Status: Offline Points: 561 |
Jon from SouthwestCNC has the only license to build them AFAIK :)
I’ll drop him a message see what’s up Edited by RoadRunnersDust - 24 October 2018 at 2:56pm |
RoadRunnersDust
For 90-250 you could also use the old Turbosound TSE cabinets (Scream Audio Builds on FB have plans for a couple of bins that should also cover 90-250 reasonably well) Edited by RoadRunnersDust - 24 October 2018 at 3:01pm |
