  New Posts New Posts RSS Feed - Kick/Bass Bin-cabinet for 90-360hz
 Post Reply Post Reply Page  123 6>
KMB View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KMB Quote  Post ReplyReply Direct Link To This Post Topic: Kick/Bass Bin-cabinet for 90-360hz
    Posted: 11 October 2017 at 1:44pm
Which bin would be good for 90-360hz?
Kick bin
Mikkel View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikkel Quote  Post ReplyReply Direct Link To This Post Posted: 11 October 2017 at 6:22pm
The MKB 230 and MKH 230 should do 90-380. Never heard them before but the MKH 230 looks good.
Sorry i meant the MKB, freespeakerplans seem to have the same plan up for both cabs?
Anyway i'll post links to plans just to avoid any confusion.
http://hornplans.free.fr/mkb230.html
http://hornplans.free.fr/mkh230.html
Edited by Mikkel - 11 October 2017 at 6:33pm
luton_soundman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote luton_soundman Quote  Post ReplyReply Direct Link To This Post Posted: 11 October 2017 at 9:59pm
Thats kick, low midrange and midrange if you play to 360hz
bob4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bob4 Quote  Post ReplyReply Direct Link To This Post Posted: 12 October 2017 at 5:34am
check this thread: https://forum.speakerplans.com/kickbins-for-hogs_topic99158_page2.html
freespeakerplans has a glitch with the mkb/mkh230 plan, they are NOT the same, but actually two different cabs. Someone should tell them to fix that LOL
corell View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote corell Quote  Post ReplyReply Direct Link To This Post Posted: 12 October 2017 at 1:00pm
MKB will never play to 380 Hz, even MKH struggles to do so.
KMB View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KMB Quote  Post ReplyReply Direct Link To This Post Posted: 12 October 2017 at 1:20pm
so do you know a bin that would play untill 360?
KMB View Drop Down
do you know which bin can produces freq untill 360hz?
Post Options Post Options   Thanks (0) Thanks(0)   Quote luton_soundman Quote  Post ReplyReply Direct Link To This Post Posted: 12 October 2017 at 2:31pm
Why does it need to go to 360hz? What speaker/cab is it meeting?
Peter Jan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Peter Jan Quote  Post ReplyReply Direct Link To This Post Posted: 12 October 2017 at 3:40pm
Years ago I made some "C-bins", designed by someone on this forum (Centauri).
That design can easily go up to 4-500 Hz, with a 15 "speaker that can go this high.
Not an easy build, but it has manageable dimensions and down low it performed also good to 50-60 Hz with ease.
Other than that I would suggest a BR cab...
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikkel Quote  Post ReplyReply Direct Link To This Post Posted: 12 October 2017 at 5:14pm
good to know. I was only going off the frequency response graphs on the webpage.
bass*en*mass View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bass*en*mass Quote  Post ReplyReply Direct Link To This Post Posted: 12 October 2017 at 6:15pm
james/timebombs rb212s would work, peter morris diy 12" section too, almost any reflex loaded cab aswell.. 360hz xover is indeed uncommon - what tops do they have to meet, which bass cabs and size of stack/coverage?
KMB View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KMB Quote  Post ReplyReply Direct Link To This Post Posted: 13 October 2017 at 9:43am
well i have a 4 way pre amp with kick 92-360hz..
This page was generated in 0.139 seconds.
