La Scala build |
krl123
Joined: 11 November 2023 Location: LANSING MICHIGA Status: Offline Points: 3 |
Topic: La Scala buildPosted: 27 November 2023 at 12:01am |
I am just starting to look for good plans to build the Klipsch La Scala speaker cabinet.. anyone out there knows of a plan I can download and work from.
thank you Kevin |
jazomir
Joined: 20 November 2006 Location: Sunderland UK Status: Offline Points: 1759 |
Posted: 29 November 2023 at 7:25pm |
Have you tried Googling 'klipsch lascala plans'? There are dozens of plans and info online if you look as well as numerous reasons to not build them. Firstly the plans are technically 'Intellectual Property' and second, unless you can get the exact same drivers and same x-over they will not sound the same as the original. The plans may be a good starting point for self build but unless you have loads of time and access to loads of different drivers to identify which are the most suitable and best sounding I would follow the examples of previous builders.
Hope this helps.
bob4
Joined: 29 February 2004 Location: Finland/Germany Status: Offline Points: 1924 |
Posted: 30 November 2023 at 1:02pm |
https://community.klipsch.com/index.php?/topic/91448-la-scala-bass-mod-again/
Edited by bob4 - 30 November 2023 at 1:09pm |
