  New Posts New Posts RSS Feed - LA5
LA5
doober View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote doober Quote  Post ReplyReply Direct Link To This Post Posted: 21 September 2020 at 7:48pm
Thanks for the info. Your EQ looks very similar to what I've tried on my home made waveguide with a BMS 4538. Response looks similar too. That's great news for me.
The reason I asked if both 5" drivers are run together relates to off axis response, something else I've been looking into recently. My calculations suggest that you will get -6dB at 45 degrees off axis, at around 625Hz. This is based on a guess that your drivers are 260mm centre to centre. I haven't tested this calculation yet- have you noticed this dip at all?
Blahblahblah
dlyxover View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dlyxover Quote  Post ReplyReply Direct Link To This Post Posted: 21 September 2020 at 9:52pm
I was curious if that is common with this type of wave guide.
The driver centres is 251mm (good guess), I haven't noticed any significant nulls when listening; not measured off axis yet.
There is a 7db dip @ 600hz but also @ 300hz, and 220hz, put this down to the measuring environment as the continuity gets skittish at those points also.
Have a BMS 4524 I'm going to try.
Lignum_ww@icloud.com
GNKaudio@icloud.com
Post Options Post Options   Thanks (0) Thanks(0)   Quote doober Quote  Post ReplyReply Direct Link To This Post Posted: 22 September 2020 at 1:19pm
I just realised I calculated that wrong, the dip would be at 1250Hz. Possibly, if I got the theory and calculation right this time!
Blahblahblah
smitske96 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote smitske96 Quote  Post ReplyReply Direct Link To This Post Posted: 22 September 2020 at 3:01pm
Try the 4550 Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote dlyxover Quote  Post ReplyReply Direct Link To This Post Posted: 22 September 2020 at 3:38pm
Originally posted by smitske96 smitske96 wrote:
Try the 4550 Wink
its too big, won't fit in enclosure on the waveguide, was going to use a 4544 intiailly but it I also too large
GNKaudio@icloud.com
Post Options Post Options   Thanks (0) Thanks(0)   Quote dlyxover Quote  Post ReplyReply Direct Link To This Post Posted: 22 September 2020 at 6:30pm
put the 4524 into today
unprocessed
Orange 4538
pink 4524
processed
purple 4538
green 4524
5" & 1
grey with 4538
yellow with 4524
GNKaudio@icloud.com
Post Options Post Options   Thanks (0) Thanks(0)   Quote smitske96 Quote  Post ReplyReply Direct Link To This Post Posted: 22 September 2020 at 6:43pm
A little more expensive but they also have the newer 5530ND, diamater is only 72mm.
Post Options Post Options   Thanks (0) Thanks(0)   Quote dlyxover Quote  Post ReplyReply Direct Link To This Post Posted: 22 September 2020 at 6:56pm
dose look like a good candidate, really don't need that much power as the 5" drivers are only 80w each
GNKaudio@icloud.com
Post Options Post Options   Thanks (0) Thanks(0)   Quote smitske96 Quote  Post ReplyReply Direct Link To This Post Posted: 22 September 2020 at 7:10pm
But you can cross it lower if needed. Also headroom is always a good thing.
Running them at lower power also means less distortion Smile
Post Options Post Options   Thanks (0) Thanks(0)   Quote dlyxover Quote  Post ReplyReply Direct Link To This Post Posted: 22 September 2020 at 8:38pm
your not wrong
GNKaudio@icloud.com
Post Options Post Options   Thanks (0) Thanks(0)   Quote dlyxover Quote  Post ReplyReply Direct Link To This Post Posted: 11 December 2025 at 12:59am
GNKaudio@icloud.com
FOO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote FOO Quote  Post ReplyReply Direct Link To This Post Posted: 11 December 2025 at 9:35am
Very nice... Ports hidden in the handles?
