Lab Gruppen - Lab 2000 - psu fault |
Geigertron
Registered User Joined: 20 February 2006 Location: United Kingdom Status: Offline Points: 204 |
Posted: 07 September 2018 at 5:57pm |
I have a lab 2000 that is not powering up, the IC (U1) in the psu board is a 20 pin, yet in the manual parts list it shows as part TDA4718A which is not 20 pin (16 pin), so should it be a TDA4918a ? I can't tell as I can't read the marking. Hope someone can help, I realise this is a old amp, but I'd really like to get it working again. |
kedwardsleisure
Old Croc Joined: 20 January 2009 Location: Staffordshire Status: Offline Points: 4949 |
what psu board do you have?
If you speak to Lab they will tell you the correct part |
North Staffordshire |
Geigertron
It's shows as lab 2k psu B. I tried to make contact on their web page, but didn't have much luck, they want a proof of purchase photo, which I don't have as I bought it from eBay. |
kedwardsleisure
that's quite an oldie I'd guess. The diagram here is rev G onwards
simonp1100
Young Croc Joined: 01 September 2008 Location: Bristol Status: Offline Points: 1110 |
Looking at my service manual, the early model was using a TDA4700 & this is a 24 pin device and then the TDA4718A was later used and is a 18 pin device. I have found out through the internet that they also used UC3851, but again this is a 18 pin device.
doctor
New Member Joined: 15 November 2011 Status: Offline Points: 7 |
I think you're dealing with a
Chinese clone. For many models of LAB GRUPPEN there are Chinese clones, which also
differ from each other. Schemes and components often also differ.
Geigertron
hi guys,
Thanks for the help, I think I'm going to locate my isolation transformer & take a look on the scope
kedwardsleisure
good luck, they're a quality item after all
