lab.gruppen pdx series - any info. or impressions |
Post Reply | Page <1234> |
Author | |||
toastyghost
Judging an amplifier in watts, based on numbers, and not actual usuage, measurement, or trial by fire is just as simplistic. |
Old Croc Joined: 02 April 2004 Location: United States Status: Offline Points: 5176 |
Technically, it was judged by Rail Voltage. But unless someone has the tools to calculate RMS, Peak, Peak to Peak and the ability to understand a schematic, what I stated in my previous post is the most simplistic way to find a burst rated amplifier today equivalent to an RMS rated amplifier of yesterday. Best Regards,
burkm
Registered User Joined: 18 March 2020 Status: Offline Points: 11 |
Hi.
I am a new member of this forum Being somewhat late to the train I would like to revive the topic (last entry Nov 2019). Rms Wattage can normally be calculated by dividing the stated peak wattage by sqrt (2) or multiplying it by 0.707. The PDX3000 ist stated as a 3000 Watts peak into 4 Ohm amp, which then could be restated as an rms rated amp: 2120 Watt at 4 Ohm, 1230 at 8 Ohm and 1410 at 2 Ohm. This would put it at 1060 Watt /per channel at 4 Ohm, 615 Watt /per channel at 8 Ohm and 705 Watt/per channel at 2 Ohm (+/- tolerances). I just got one of those ominous and brand new Lab.Gruppen PDX3000 (230VAC version) amps right here, but haven't opened it yet to allow it to adapt gracefully to room temperature. Cross weight is been stated as 7.4 kg. net weight is 6.5 kg but it feels heavier to me . I will have a look inside the amp later on and listen to the noise level the built-in fans generate. Rear panel looks familiar (almost same as Behringer NX-6000D) as does the ventilation concept, as far as I can identify it. The packaging as delivered looks rather "cheap", the unit is wrapped in a foil type bag, an USB cable and a locking IEC power cord (3x0.75 mm²) plus 10A IEC Plug and a printed manual is included. Reading through the online description for the PDX3000 at the Lab.Gruppen web site looks familiar to the Behringer NX-6000D as it is internally already bridged, but power specs differ somewhat. It is supposed to be capable of driving a 2 Ohm load with reduced wattage (probably current limited) and supposed to be an "IDEEA" Class-D type amp, whatever IDEEA means. I couldn't find a "white paper" on this Lab.Gruppen specific term listed on their web site. Other "recent" amps in the Lab.Gruppen product portfolio seem to follow the same IDEEA concept. That differs from the Behringer description of their amp variants plus they can't handle a 2 Ohm load. They are almost 30% cheaper too... Unfortunately no reviews or tests are yet available. Edited by burkm - 19 March 2020 at 3:19pm |
burkm
As already promised I opened up the case and took some photos.
Unfortunately I don't have a direct comparison between this one and a Behringer NX-6000D because I don't have one, just a photo from someone else. If the current NX-6000D looks different, judging by the printed boards appearance I don't know. The printed boards are all black laquered, the two main boards carry the name of Lab.Gruppen imprinted on them. Judging by a photo of the NX-6000D innards the SMPS power supply board an the right side (viewed from the amps front) looks to me at least "somewhat similar" but not the same, the power amp board section on the left seems to differ quite a bit and additionally carries two trim pots. The DSP is an Analog Devices ADSP-21261. All electrolytic capacitors visible seem to be specified for 105°C. I haven't powered it up yet, so I can't comment on noise of the installed fans. Unfortunately I couldn't find a way of posting photos from my computer. If someone could give me a hint I would like to show some... Edited by burkm - 19 March 2020 at 6:57pm |
APC321
Young Croc Joined: 24 August 2013 Location: West Midlands Status: Offline Points: 684 |
imgbb.com works for me.
Copy and paste the link into your speakerplans message. |
burkm
Thanx for your help
If you need larger pictures, please follow the links. Note: I'm still not yet familiar with the way those images have to be inserted. Thus it looks somewhat "chaotic"... First of all, as a comparison base, the NU/NX 6000 (version ?) innards: https://ibb.co/5WDMJyD - https://ibb.co/zx25PVB - https://ibb.coCyTK41 - https://ibb.co/sgV2QZq - https://ibb.co/yY0dpd8 - https://ibb.co/zxkG7hK - https://ibb.co/CJWsFRq - https://ibb.co/GcDYynv - https://ibb.co/6JVbN08 - https://ibb.co/3srxPfM - https://ibb.co/fXswngC https://ibb.co/8M2xx2F https://ibb.co/QJcTL2h https://ibb.co/8cBWgMD https://ibb.co/5WDMJyD https://ibb.co/zx25PVB https://ibb.co/nCyTK41 https://ibb.co/sgV2QZq https://ibb.co/yY0dpd8 https://ibb.co/zxkG7hK https://ibb.co/CJWsFRq https://ibb.co/GcDYynv https://ibb.co/6JVbN08 https://ibb.co/3srxPfM https://ibb.co/Wt3bmFS Edited by burkm - 19 March 2020 at 6:55pm |
There is an Amplifier Internals Thread Part II in which, you can post the guts of the amplifier there. Since you resurrect this thread from the dead, you should have no problem finding the Amplifier Internal Thread Part II as well. If you have the proper tools, benching the amplifier under the given loads will be very helpful for those who are interested in the Lab Gruppen PDX. Best Regards,
burkm
I thought it would be better served here in the specific thread for this amp (LG PDX3000) because little technical info is available right now about his one, just "rumours". I myself searched "endlessly" fore some more info about this amp and couldn't find any, nor could I locate a dealer where I live, who had it in stock. Almost all of them on the net had it listed with long delays...
Additionally: The other thread is rather "generic"... ... and anyone searching about infos for that "new" Lab.Gruppen amp would probably be be lost searching for it, at least I were Example: I tried to find some pictures about the innards of the Behringer NU-6000D and/or NX-6000D, which is supposed to be somewhere in this forum or thread (?). I believe I had seen them (accidentally) before, but the search function didn't find anything... Edited by burkm - 19 March 2020 at 3:21pm |
You can throw it in the Amps Internal Thread Part II as well. It just makes things easier for those who are interested in the guts of an amplifier than scrounging around various threads trying to see what _______ looks like inside. It is far more technical than this thread. You generally have more repair techs visiting the Amps Internal Thread Part II which, many discuss details about the components on the PC board. I does not hurt to have the photos at two locations considering how many photos you took the time to upload. Best Regards,
U.Viktor
Young Croc Joined: 04 May 2010 Status: Offline Points: 716 |
Looks same free-oscillating INUKE with scrap switch PSU Embarrassing..
Edited by U.Viktor - 20 March 2020 at 5:57pm |
burkm
Not really if you look closer
Not only is the SMPS somewhat different, the power amp section is completely different. Edited by burkm - 20 March 2020 at 6:42pm |
APW
FFS... give it a break, you are becoming very tiresome. These are Lab's entry-level offering, they are NOT a premium tour grade amplifier and NOT advertised or priced as such. They will almost certainly do the job they are designed to do and will be fairly reliable doing it. Lab DO offer premium grade products for those who require them… The PDX series is for users who don’t need tour grade equipment. You constantly knock the inukes, Behringer are a budget brand and have shifted thousands of them world-wide, again they are NOT a tour grade product…however they work week-in week-out and have probably generated their combined owners/operators far more revenue than the likes of PKN could ever dream of…. ….Some people cannot afford or want a Porsche; often a Skoda is all that’s required, either way they are both made by the WV group!! Edit: BTW, I’m not in any way knocking or anti PKN; I’m just tired of YOUR constant bashing of EVERTHING that isn’t PKN!
Edited by APW - 20 March 2020 at 9:16pm |
