Lab Gruppen Signal Lights and SPT issue |
Trickeytom
New Member Joined: 11 November 2021 Status: Offline Points: 2 |
Posted: 11 November 2021 at 10:39pm |
Hi all Never posted on here before to let me know if this isn’t the right kind of content to post. Looking for some advice.. I’ve got a Lab Gruppen E Series 4:2 running the tweeters on my mid-tops and had an issue with it turning off after 20 minutes. I found in the manual about the Input Signal Present Threshold (Spt) and followed the instructions to press the power button for 2 full seconds. It worked. But the issue has come up again and pressing the power button for two full seconds doesn’t fix it.Also when I’m looking at the amp the Signal lights (Sig) are not flashing at all but music is playing through it at a decent volume. It’s like it’s playing music but it’s not recognising that it is in the software, something like that. The volume is set to half way so it’s not like the volume is super high so that the signal needs to be really low… I’m running it from an FFA 4004 with an in-built DSP. Any ideas? Thanks Tom
