Lack of sizzle in midtops |
Post Reply | Page 12> |
Author | |||
r.G
Registered User Joined: 23 April 2015 Location: Germany Status: Offline Points: 64 |
Posted: 06 June 2017 at 9:47pm |
Greetings,
I've been running a small soundsystem for a few months now and this forum has helped greatly with advice and information. Now I'm not quite happy with the sound of my mids and tops. What I'm missing is the presence of that typical clave sound, in lack of better words, I'll call it sharpness. The sizzle in your ear, like someones poking your eardrum, but without any pain. Overall, I think my midtop section sounds pretty clear, but I lack the roughness and character of real reggae sound. Now, I don't know in which frequency area that is. My setup are two supers with 18 XB in it, a HD215 with Kappas and I'm kinda happy with the performance and sound of those. Mids are a 2x12" sealed, angled mids. I think it is a Celestion design, but not too sure. They're loaded with Fane Sorvereign 12-300. My top section consists of a BMS 4554 1,4" CD on the B&C ME90 horn. Now my question is, is the lack of sharpness down to the components itself, the cab design or can it be fixed with some EQing? Any advice welcome! rg
gen0me
First take eq and check what frequency that is
r.G
I did try running a basic clave/woodblock sample through a frequency analyzer and boosted the affected area a bit, but that didn't do the trick.
gen0me
So you know what freq it is?
Any photos or screenshoots welcome Edited by gen0me - 06 June 2017 at 10:26pm |
r.G
Did it a while ago, so no screens. Atleast the clave sample I used was mainly around 2,4-2,8kHz area.
gen0me
You can fight with eq. Use spikes rather than wide bands. If wont help change driver.
What is clave? Edit I see you meant instruments. So rather wider spikes. Edited by gen0me - 06 June 2017 at 10:46pm |
RiddimKid
Young Croc Joined: 22 October 2006 Location: United Kingdom Status: Offline Points: 847 |
I would add Four Bullet tweeters. Either the MNC eBay specials or if you can stretch your budget then some Beyma CP22.
bass*en*mass
add a mild high shelf filter boost above 10ish khz.. + either a mild low shelf cut below 5ish khz/or wide Q parametric cut at about 3khz + a couple of narrow parametrics at resonances..
those bms drivers need quite some eq imho to sound ok.. naturally they dont lack "sharpness" imo those horns are 80x60° dispersion, make sure to splay them properly to "avoid" comb filtering! |
Sypa
Young Croc Joined: 21 February 2013 Location: Croatia Status: Offline Points: 920 |
Maybe you miss the distortion of the 2" in the 2-3-4 khz range,lots of people actually like that ,that sizzling high hats which are mistaken sometimes for very high frequency.
r.G
I don't really want to upgrade to 5 ways. If necessary, I'd prefer to upgrade the top section to something more potent. I also don't think it's the top end lacking, it is probably what Sypa said: \/
Yes, most likely. It is the hihat/clave frequency range that thunders in your ear. As mentioned before, I tested a clave sample, which was around the 2,6kHz region and it didn't deliver there, atleast not as I'd like it to. I know some people who can't stand that and think it is unpleasant, but personally I like the sizzle.
Would you mind explaining a bit? I'm running a behringer ultradrive. How do I apply shelving filters with it? Parametrics at resonances? Thanks for the input so far Edited by r.G - 07 June 2017 at 9:26am |
Sinai Sound
Young Croc Joined: 09 November 2009 Location: Sheffield Status: Offline Points: 631 |
That's near exactly what I've done, they tail off after about 6khz, so need some EQ to get that sound you want If that's still not the sound you'd like, using a 4 bullets and a passive crossover, you could still have a 4 way sound as it wouldn't require an extra amp channel
Edited by Sinai Sound - 07 June 2017 at 9:30am |
Sinai Sound
Higher Fidelity built these for our friends in Sheffield, They run it active, but with a crossover in the back you could run it passive Edited by Sinai Sound - 07 June 2017 at 2:15pm |
