lack of top end |
Aaronski
Registered User Joined: 05 January 2011 Location: norwich, uk Status: Offline Points: 90 |
Posted: 03 November 2013 at 5:37pm |
some one educated me on comp and horn selection please
I understand the horn dispersion on 122's should be 60x40 and thats way im using the p audio 2723. i am using the beyma cp750ti comp but im getting a lack of response above 9k why is this, wrong comp im guessing? but why?
corr that sounds well good, how many k is it pushin? what amps you got? turn it up abit mate.
Tony Wilkes
It will need EQing to get the sparkle, what are you applying?
Tony |
kevinmcdonough
Old Croc Joined: 27 June 2005 Location: Glasgow Status: Offline Points: 3749 |
hey
yeah all compression drivers need some EQ at the top end to compensate for the effects of the CD horn, google CD horn EQ and you'll get some ideas. k |
Artical Kulcha
Registered User Joined: 02 October 2013 Status: Offline Points: 192 |
True, with comp's and horn
yes higher the frequency lower the efficiency, so will need a bit of EQ to make up for this.
Aaronski
comp is playing 900hz up
EQ for the top end, iv got +5db 12/oct high pass @8.5k how much can i boost it?
any recommendations? |
kevinmcdonough
hey
As you get closer to a compression drivers top end it naturally starts to beam and be less efficient. The compression driver CD (constant directivity) horn then takes what is a smaller amount of sound to start with an spreads it out even further trying to counteract the beaming and make it stick to the coverage pattern, diluting it even more. So there are some fairly specific requirements needed to help even this out and boost the top end to make it flat again. Its an actual thing that needs compensated for on all comps and horns, be it by the passive internal crossover or by the active external one. As I said if you google constant directivity horn EQ you'll find loads of info and suggestions, for example..... http://www.peavey.com/support/technotes/soundsystems/horn_eq.cfm k Edited by kevinmcdonough - 04 November 2013 at 9:13pm |
Aaronski
cheers guys, ill do some research and prob be back with more questions ;)
