l-acoustic plans |
paddyd11
Topic: l-acoustic plansPosted: 27 March 2006 at 7:18am |
does anyone know of any plans for the arc or sb218 boxes from l-acoustic cheers in advance
MPASOUND
Joined: 25 April 2006 Location: UK Status: Offline Points: 272 |
Posted: 25 April 2006 at 12:01pm |
Think you'll find that these are copyrighted and could end up getting you into trouble!!Besides,ARCS use a simple reflex 15" with a complex custom moulded horn flare....I doubt you would be able to make one without access to an injection moulding machine.If it were that easy they wouldn't be able to charge such an insane price for them!! Cheers. |
ceharden
Posted: 25 April 2006 at 9:14pm |
The SB218 is a simple twin 18" reflex box using Beyma drivers.
I'd guess each driver probably has about 180L enclosure volume and
tuned to 40ish Hz.
Basically identical to a G-sub, so why not build one of those! MPASound is right about the ARC. I wouldn't recommend building copies even if you could. I use them a lot and they have their place but there are probably better boxes out there. |
