  New Posts New Posts RSS Feed - Laser?
Laser?
stan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote stan Quote  Post ReplyReply Direct Link To This Post Topic: Laser?
    Posted: 17 February 2009 at 11:21am
We are thinkin of purchasing a laser and smoke/haze machine but wasnt quite sure what to go for. I have been lookin at the  Kam TRI160 DMX Laser and the Acme HP2S 700 Watt Stage Hazer, has any body got any views/suggestions?
Cheers
Stan
Post Options Post Options   Thanks (0) Thanks(0)   Quote mk2_ginger_biscuit69 Quote  Post ReplyReply Direct Link To This Post Posted: 17 February 2009 at 12:32pm
1). use the lighting page at the bottom of the main menu.....
2). what kind of size venues, what budget, inside or outside, blah blah blah..... smoke/haze is already massively discussed, and lasers is pretty much pay for what u get!!
stan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote stan Quote  Post ReplyReply Direct Link To This Post Posted: 17 February 2009 at 12:42pm
totally didnt see the lighting section at the bottom
we mainly just do indoor small/medium size venues and probably wanna spend bout 300/400
norty303 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote norty303 Quote  Post ReplyReply Direct Link To This Post Posted: 17 February 2009 at 12:47pm
Really, if you want to know about lasers go to www.photonlexicon.com/forums
More information than you can shake a coherent stick of light at.
£300 - £400 for hazer and laser is not much really, and you don't get much laser for a few hundred quid.  also, if you're looking at class 3b lasers, make sure you're aware of the safety implications.
stan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote stan Quote  Post ReplyReply Direct Link To This Post Posted: 17 February 2009 at 12:54pm
cheers for the info
safety implications?
doober View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote doober Quote  Post ReplyReply Direct Link To This Post Posted: 17 February 2009 at 1:23pm
You really don't want a punter, or yourself, getting an eyefull of laser beam.
Kieran
Blahblahblah
Post Options Post Options   Thanks (0) Thanks(0)   Quote norty303 Quote  Post ReplyReply Direct Link To This Post Posted: 17 February 2009 at 1:28pm
If you have to ask you don't know enough....
Lasers burn your eyes out.  The lasers they use for corrective surgery are as small as 150mW in cases.
In the USA they don't allow crowd scanning with anything over 5mW without hard to obtain variances.  In the UK (if the H&S are doing their job) you should be required to produce calculations to show MPE (maximum permissible exposure) is not exceeded in the crowd zones, or you simply don't crowd scan.  In the UK we have a Health and Safety Executive document that covers it - HSG95 (£10)
The subject is huge, the maths mind boggling....   photonlexicon may be a really good eye opener and source of info ;)
