  New Posts New Posts RSS Feed - LD systems dp600.
LD systems dp600.
d.antonis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote d.antonis Quote  Post ReplyReply Direct Link To This Post Topic: LD systems dp600.
    Posted: 05 February 2026 at 6:23pm
   This amplifier came to my hands, in near mint condition. Everything inside was pretty clean, only the fan had some dust. The amp had a very low usage at a small conference room with speech volumes. I thought that it was a humble cousin of behringer, for example, and other low budjet units ,but when i tested it with four 400w pa speakers, i changed my mind. Its power seem to be far more than specs indicate, and i had to lower the volume for my ears safety. Of course the test was indoors, i have to test it outside to find out its full potential.
   I just wanted to share this with you, and to ask if someone have these amps to share experience using them, thanks.....
Edited by d.antonis - 05 February 2026 at 6:29pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote d.antonis Quote  Post ReplyReply Direct Link To This Post Posted: 05 February 2026 at 6:29pm
   Also, i have to add that it has only 4 output transistors per channel (njw0302-njw0281 pairs), two bridge rectifiers, mosfets, and two main transformer windings, meaning its a class-H topology.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Earplug Quote  Post ReplyReply Direct Link To This Post Posted: 06 February 2026 at 8:21am
I know 1 guy that has a few of the LD PA series amps & is quite happy with them. Sort of mid-range, quite well built amp. Maybe comparable with the Thomann stuff. Ok if you're on a budget & don't mind the weight!   Smile
