  New Posts New Posts RSS Feed - Lectriflex
Lectriflex
dmx256 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dmx256 Quote  Post ReplyReply Direct Link To This Post Topic: Lectriflex
    Posted: 29 August 2017 at 7:32pm
Anyone on here still using lectriflex (16 pole harting) over socapex for generics?
Logic System XTA EAW MC2 Robe Anytronics Futurelight Trilite Tas and a wife....
monkeypuzzle View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote monkeypuzzle Quote  Post ReplyReply Direct Link To This Post Posted: 29 August 2017 at 9:23pm
Think Whitelight had a load of it (that was three or four years ago mind). Was actually the designers preferred choice of connector as he said it was better for the job of being left outside for the best part of a month and there was about 2km of it on the job spread around the site. I've used Soca outside loads of times and never had a problem with water ingress, usual culprit is the idiot that tapes a 16a vertically so the water just runs straight in through the cable hole....
James Tengo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote James Tengo Quote  Post ReplyReply Direct Link To This Post Posted: 30 August 2017 at 2:51am
Plenty of European companies still using it, due to ze Germans not liking soldered mains connectors. I've got a crimped socca end for showing to 'elf n saftey gnomes in German arenas, not met one yet that has asked me to open up one that I'm actually using...
This page was generated in 0.297 seconds.
