  New Posts New Posts RSS Feed - Letterbox X1 plan
Letterbox X1 plan
norty303 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote norty303 Quote  Post ReplyReply Direct Link To This Post Posted: 23 October 2009 at 5:29pm
Quote Unless your build is 8mm out, in which case it won't fit
that almost sounded like the dreadful voice of experience
Dougies Music View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dougies Music Quote  Post ReplyReply Direct Link To This Post Posted: 23 October 2009 at 6:11pm
cyte View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cyte Quote  Post ReplyReply Direct Link To This Post Posted: 04 November 2009 at 5:45pm
Originally posted by norty303 norty303 wrote:
Letterbox measured slightly lower response.  Rog said it was prob due to the larger port area in contact with the ground plane.
are they any other effects of changing chamber dimensions (but maintaining the same volumes)? (in general, not just the X1)
Edited by Corticyte - 04 November 2009 at 5:46pm
Abo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Abo Quote  Post ReplyReply Direct Link To This Post Posted: 10 December 2009 at 1:17am
so letterbox x1 and then mod it with 2 8mm panels on the sides would be fine then ?
cravings View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cravings Quote  Post ReplyReply Direct Link To This Post Posted: 10 December 2009 at 1:45am
8mm panels what? fine for what?
backlash View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote backlash Quote  Post ReplyReply Direct Link To This Post Posted: 14 February 2010 at 3:30pm
To make it fit the V18-1000 when your is build 8mm out!
Sound Hire
DjTAB View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DjTAB Quote  Post ReplyReply Direct Link To This Post Posted: 28 February 2012 at 6:23pm
I now have four of these babies to load with Void V-18's.
Can't.
Effing.
Wait.
Smile
bee View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bee Quote  Post ReplyReply Direct Link To This Post Posted: 28 February 2012 at 8:24pm
errr no.... its the internal measurement that matters..... you can add 25mm panels on the side if you want, but it will still be 8mm internally to small......
the rule hear is measure twice cut once.
mini-mad View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mini-mad Quote  Post ReplyReply Direct Link To This Post Posted: 16 July 2012 at 9:03am
lol.... i think that shot rite over his head...... lol
SerenitySoundSystem View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SerenitySoundSystem Quote  Post ReplyReply Direct Link To This Post Posted: 27 March 2017 at 8:36pm
has anyone got an updated plan of the letter box X1?
i have two and want another 2 built ASAP!
thanks guys and gals!Big smile
