Levyte scoop design |
Page <1234 20> |
| Author | ||
Static Age
Joined: 14 November 2005 Location: Oxfordshire Status: Offline Points: 1652 |
Posted: 22 January 2008 at 1:55pm |
looking good lev, its very similar in some ways to my recent scoops.
i think this will be alot better than your previous plan.
Tekasis
Posted: 22 January 2008 at 2:23pm |
Looking good & details sounds good!
Heathrow_B_line
Joined: 11 January 2006 Location: United Kingdom Status: Offline Points: 7339 |
Posted: 22 January 2008 at 2:39pm |
how similar is this design to the RX18?
levyte357
Joined: 10 May 2004 Location: UK, London Status: Offline Points: 11743 |
Posted: 22 January 2008 at 2:46pm |
Dont know. Never seen the inside of an RX18. But it does have larger chamber than RX18/Scooper, and shorter rear board. And completely different scoop than those two also. It is is based on JBL/Fane design internally, but with larger chamber, and Superscooper exterior, so I guess it has many fathers.. ![]() |
tweeter box
Joined: 21 October 2007 Location: United Kingdom Status: Offline Points: 6784 |
Posted: 22 January 2008 at 3:48pm |
jethrocker
Joined: 07 June 2006 Location: Chiapas, Mexico Status: Offline Points: 1942 |
Posted: 22 January 2008 at 11:40pm |
Lev, what exactly are you taking as rear chamber/throiat measurements...looks tricky to me. To my eyes it looks like there is some compression right up to the corner where the first horn section starts to go up behind the chamber, this would make for a very large chamber, but not such a llarge throat, and a shorter horn of course. Might not work like that in practice as there is some expansion from the end of rear baffle board through the first bend, but then a little compression after?
Looking like a good all rounder though.. ideal roots sound box, should play good in medium-small venues and be flexicle on driver choice. Might not sound too tight in a big stack.. |
levyte357
Posted: 23 January 2008 at 3:17am |
This is exactly what its for. The cab will definetly perform with the drivers I need it to (PD1850/Bline 800,V18-1000). I just added in flexibility for future upgrades {V18-1200/Turbomax} ![]() I wouldnt be using scoops for any venue requiring more than 2x stacks of 6. Not really looking for tight sound, but rear chamber is not too big for tight driver like V18-1000. |
levyte357
Posted: 23 January 2008 at 2:59pm |
Design updated for easier construction/bracing, and front almost identical to Super.
CHAMPION
Joined: 30 September 2004 Location: United Kingdom Status: Offline Points: 3667 |
Posted: 23 January 2008 at 7:59pm |
Scooper Lev get cracking then,,,,knock them up then ....The cab needs to be tryed and tested, its all well and good on paper.
Start building
Sticks n Stones
levyte357
Posted: 24 January 2008 at 12:10am |
No problem boss. I'll build them as soon as I learn how to spell router, and what it is, and how to build cabs. And which end to hold a chisel. |
mykey
Joined: 18 August 2005 Location: UK/Indonesia Status: Offline Points: 9680 |
Posted: 24 January 2008 at 2:43am |
hold it the blunt end
CHAMPION
Posted: 24 January 2008 at 8:16am |
I carnt iv got a few jobs on the go ! Edited by CHAMPION - 24 January 2008 at 10:14am |
Sticks n Stones
Page <1234 20> |
