Levyte scoop design |
Page <12345 20> |
| Author | ||
tweeter box
Joined: 21 October 2007 Location: United Kingdom Status: Offline Points: 6784 |
Posted: 24 January 2008 at 9:24am |
It is isnt it?
Heathrow_B_line
Joined: 11 January 2006 Location: United Kingdom Status: Offline Points: 7339 |
Posted: 31 January 2008 at 10:22pm |
any progress or have you been busy with other things?
Edited by Heathrow_B_line - 31 January 2008 at 10:22pm |
Heathrow_B_line
Posted: 01 February 2008 at 1:29pm |
will there be a cut sheet?
levyte357
Joined: 10 May 2004 Location: UK, London Status: Offline Points: 11743 |
Posted: 01 February 2008 at 1:34pm |
Busy getting estimates for a proto build, but I'm seriously thinking about just getting first 1x done in ply |
Heathrow_B_line
Posted: 01 February 2008 at 1:40pm |
ply would be good if you want to go with Tekasis's idea and only glue one side down, leaving the other to be unscrewed allowing you to change things as and when you wish
levyte357
Posted: 01 February 2008 at 1:41pm |
To be honest, took 90% of my brain cells to get it this far. I think it takes building experience to do a decent cutsheet. Was hoping builder/CAD genius like yourself might help out. Edited by levyte357 - 26 April 2008 at 5:57am |
Heathrow_B_line
Posted: 01 February 2008 at 1:49pm |
CAD support is no problem, 3d visualisations too. Rates start from around £20 per hour depending on how precise your input parameters are and what quality of output your looking for. if you need an 'estimate' let me know
EDIT: if you put another drawing up with all the angles marked on it clearly you may get away with not doing a cut sheet. this may be easier for you as you already have a rough drawing Edited by Heathrow_B_line - 01 February 2008 at 1:56pm |
levyte357
Posted: 01 February 2008 at 2:18pm |
Possibility, but short of time so may get the builder to gimme cut list for posting. I'm most likely gonna get proto glued and screwed,As I "think" the only tuning needed for different drivers will be length of rear bafle. |
Heathrow_B_line
Posted: 01 February 2008 at 2:29pm |
it is your choice, but if you go back to your drawing package and check the flare along the first 180 degree bend i think you will find that the flare rate is wrong and doesnt expand like it should.
levyte357
Posted: 01 February 2008 at 4:18pm |
Well, the drawing is here to be discussed/corrected. What do you propose the correct widths around the first bend should be? |
Heathrow_B_line
Posted: 01 February 2008 at 4:31pm |
we shall have to see what our man from wattco thinks
he might have a better eye for these things
GIVEorTAKE
Joined: 20 May 2006 Location: United Kingdom Status: Offline Points: 342 |
Posted: 01 February 2008 at 6:21pm |
Have you tried Google SketchUp ?It's a great freeware that will help you draw and see in 3d your box.it'seasy as paint, and when you have finished your model you can download the "Pro version" (8 hour trial) and export your drawing to Autocad for further tweakings...
Page <12345 20> |
