  New Posts New Posts RSS Feed - LF18X401 in scoop?
LF18X401 in scoop?
moyojojo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote moyojojo Quote  Post ReplyReply Direct Link To This Post Topic: LF18X401 in scoop?
    Posted: 05 January 2022 at 6:14pm
Hello,
Did anyone tried to put this driver in scoop?
Thanks for reply.
Edited by moyojojo - 05 January 2022 at 6:14pm
levyte357- View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote levyte357- Quote  Post ReplyReply Direct Link To This Post Posted: 06 January 2022 at 9:44am
Originally posted by moyojojo moyojojo wrote:
Hello,
Thanks for reply.
As suggested previously, I would suggest you sell that driver, if intending to use Scoops.
This is a free plan, from the very generous "Mykey Wattco", that will work with many of the best Scoop drivers.
https://forum.speakerplans.com/fane-scaled-up_topic74640_page1.html
This Mod will increase the number of drivers that will sound good, in this cab.
https://forum.speakerplans.com/fane-scaled-up_topic74640_page6.html
"So by taking 450 and reducing it to 425mm will give you a bigger chamber and throat without messing with anything else. This would give you the sound that most scoop lovers are looking for these days
70 litres minus driver 18'' = roughly 11 litres would leave 59 litres and a throat size of 849
Chamber and throat are close to Wattco scoop territory"
Edited by levyte357- - 06 January 2022 at 9:55am
bob4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bob4 Quote  Post ReplyReply Direct Link To This Post Posted: 07 January 2022 at 12:22pm
Shocked
Wow, an unprecedented moment in the scoop section!
Clap
In proper Christmas spirit, Lev is making it snow for everyone!
Thumbs Up
Thank you for the link Lev, interesting reading
Happy New Year! Cool
Post Options Post Options   Thanks (0) Thanks(0)   Quote levyte357- Quote  Post ReplyReply Direct Link To This Post Posted: 07 January 2022 at 12:37pm
Originally posted by bob4 bob4 wrote:
Shocked
Clap
Thumbs Up
Eh, stop that.. !!! LOL
Just doing, what I tell everyone to do, when someone asks for help..
Tell them to search Scoop Forum, for all the treasure that is here !!
Post Options Post Options   Thanks (0) Thanks(0)   Quote moyojojo Quote  Post ReplyReply Direct Link To This Post Posted: 07 January 2022 at 12:37pm
Shocked
Ha xd
More explanation here: https://forum.speakerplans.com/topic106748_post1057061.html#1057061
So, maybe another question - what cabinet should I use for this RCF?
smitske96 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote smitske96 Quote  Post ReplyReply Direct Link To This Post Posted: 07 January 2022 at 1:46pm
@levytout
of curiousity.
Why would that small descrease shift the 'boundary' for the chamber that much?
Post Options Post Options   Thanks (0) Thanks(0)   Quote levyte357- Quote  Post ReplyReply Direct Link To This Post Posted: 07 January 2022 at 2:18pm
Originally posted by smitske96 smitske96 wrote:
@levyte
of curiousity.
Was Mykey who originally stated this.
But would "imagine", reducing the rear baffle shifts the throat, and includes additional bit of chamber volume.
Edited by levyte357- - 07 January 2022 at 2:19pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote levyte357- Quote  Post ReplyReply Direct Link To This Post Posted: 07 January 2022 at 2:23pm
Shocked
Ha xd
Do you not get the "strong hints", sir !?
For Dub Reggae, Scoops are one of the "optimal" cabs.
You have a great free design here.
Look for drivers, with BL, Vas, Qts, Qes similar to Void V18-1000,PD1850 MK2, PD1852, to use in this cab.
B&C 18TBX100 will also work, but won't be as loud, or as sturdy, as the above.
Edited by levyte357- - 07 January 2022 at 2:26pm
jammin75 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jammin75 Quote  Post ReplyReply Direct Link To This Post Posted: 07 January 2022 at 3:08pm
Shocked
Ha xd
For Dub Reggae, Scoops are the "optimal" cabs.
sorted LOL
Post Options Post Options   Thanks (0) Thanks(0)   Quote levyte357- Quote  Post ReplyReply Direct Link To This Post Posted: 07 January 2022 at 3:19pm
sorted LOL
You naughty man !!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote jammin75 Quote  Post ReplyReply Direct Link To This Post Posted: 07 January 2022 at 3:51pm
scoop owners drink wray and nephew   reflex owners wud be on the captain morgan !!   LOL
Edited by jammin75 - 07 January 2022 at 6:15pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote toastyghost Quote  Post ReplyReply Direct Link To This Post Posted: 08 January 2022 at 11:51am
@levytout
of curiousity.
You're only decreasing the area through the bend by 0.02 litres, but there will be an increase in the compression ratio as this is in effect the throat for the horn.
Making a change to the coupling chamber adjusts the roll-off in the upper region of the horn's output, which will affect the summation (or cancellation) with the pressure directly radiating from the front of the driver. Often that's modelled as a series compliance, when in reality it's more of a transmission line which is affected by the driver's placement along the initial chamber.
Anyway, a key thing for 'scoops' is that the horn's geometry sizing parameters are pretty much uncoupled from the choice of driver, for an exponential flare profile. The primary factors are simply the desired cut-off frequency, and the amount of SPL increase desired over a simple direct radiator in an infinite baffle.
Contrary to popular opinion here, a scoop or rear-loaded horn is pretty well understood, acoustically. Part of the disconnect between sims and ‘perceived reality’ seems to be twofold - people rarely build what they simulate, and even more rarely qualify/refine the model with measurements of the box that's been built.
Anyway, that aside, this is a great resource in fairly plain English for this type of box:
http://www.quarter-wave.com/Horns/Horn_Theory.html
Try to your way through them in turn, even if you're impatient, like me
