  New Posts New Posts RSS Feed - LIMMER 308
LIMMER 308
mark68 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mark68 Quote  Post ReplyReply Direct Link To This Post Topic: LIMMER 308
    Posted: 23 February 2009 at 10:08pm
HI,  what do you think about Limmer 308?
could it  be a good solution for top   mid high application?
which drivers I could use in this horn?
any suggest?
or it will be better to choose  the porn horn
thanksSmile
Rockin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockin Quote  Post ReplyReply Direct Link To This Post Posted: 24 February 2009 at 11:13am
I love the look of the Limmer range
http://www.lsv-achenbach.de/daten/limmer.htm
I believe Dom on these forums uses or used a Limmer horn with a Porn MK1 and seem to remember good comments about the sound
Thorsten View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thorsten Quote  Post ReplyReply Direct Link To This Post Posted: 06 April 2009 at 3:33pm
Dom View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dom Quote  Post ReplyReply Direct Link To This Post Posted: 06 April 2009 at 7:09pm
I do still use the Limmer 308/Mk1 Porn Horn combo...
I think it's a nice combination.  As for drivers you need to use the Ciare 6.38MR3, as the horn and phase plug are designed for it.  You could use any 1" but you'd need a good reason not to use the B&C DE250....
Dom View Drop Down
Oopps, my mistake...  I use the Limmer 042...
unknown_artist View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote unknown_artist Quote  Post ReplyReply Direct Link To This Post Posted: 22 April 2009 at 1:24pm
First of all: I don't think that the Limmer 308 and the Pornhorn are compareable.
The Limmer has got a wider spread and isn't much bigger than a Nexo PS15.
The recommended drivers (a good designed passive crossover plan is available) are B&C 12PE32 and DE700.
I chose the 18Sound NSD 1480, imho the better HF driver with an active crossover.
But the Pornhorn has got much more lowend than the limmer, a result of the long midhorn...
Father-Francis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Father-Francis Quote  Post ReplyReply Direct Link To This Post Posted: 22 April 2009 at 4:11pm
the one that has been tried is the 042, from what I can read , i think he wants to know if the 308 could also work , maybe it´s just the top end he needs.
shadow1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote shadow1 Quote  Post ReplyReply Direct Link To This Post Posted: 22 April 2009 at 4:39pm
I like Limmer !
tweeter box View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tweeter box Quote  Post ReplyReply Direct Link To This Post Posted: 15 May 2009 at 5:10pm
they look wicked, where can i get prices? bet they cost a bomb though!
boycey View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote boycey Quote  Post ReplyReply Direct Link To This Post Posted: 15 May 2009 at 5:29pm
all the prices are on the speakerstore.nl page in euros. you get what you pay for
my experience of the 042 is overwhelmingly positive, got them for about £300 each including drivers, about the same as a decent 1.4" plus horn but dropping much lower.
the only thing more dangerous than a person who doesn't give a f**k is a person who gives a sh*t.
audionik View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote audionik Quote  Post ReplyReply Direct Link To This Post Posted: 30 July 2009 at 4:53am
Did you ever compare dn 1480 to dn 1460 ?
By.
Jake_Fielder View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jake_Fielder Quote  Post ReplyReply Direct Link To This Post Posted: 30 July 2009 at 9:29am
Oh i was looking at these limmers yesterday,
Does any one have the 308?
This page was generated in 0.066 seconds.
