  New Posts New Posts RSS Feed - Limmer horns combination.
Crazy Dane View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Crazy Dane Quote  Post ReplyReply Direct Link To This Post Topic: Limmer horns combination.
    Posted: 19 December 2018 at 7:52pm
Hi Guys.
Looking into making new mid/high cabs to go above 3 to 4 HD15 and some gsubs.
First i thougth of the MT122, but its to deep.
And then i came across limmer horns 308 and 312. Can these be combined in one cab without messing to much with coverage, phase allignment and all that stuff? 308 on top and 312 just underneath it.
Havent been able to find much info on Them, but they should use the same 12" as far as I understand.
Best regards Frank
Best regards... Frank
boots-hifi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote boots-hifi Quote  Post ReplyReply Direct Link To This Post Posted: 19 December 2018 at 10:54pm
Where are you getting the horns from? I can only find the limmer site, but no price lists. MT121’s loaded with decent drivers still hold their own.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Crazy Dane Quote  Post ReplyReply Direct Link To This Post Posted: 20 December 2018 at 8:57am
Its second hand from a guy in sweden. Dont know if limmer horns are still in production.
I like the simple design and straight forward build of the mt121 and 122, but they are to deep to fit on top of the HD15.
One thing i dont like about the mt122, is the HF horn placed in the middle.
Miles View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Miles Quote  Post ReplyReply Direct Link To This Post Posted: 20 December 2018 at 9:24am
it is not a problem to stack mt121/122 on hd15s even if they are +-20cm deeper -  there are also lots of ppl who redesigned the mt122 with the HF Horn on Top instead of in the middle
Post Options Post Options   Thanks (0) Thanks(0)   Quote boots-hifi Quote  Post ReplyReply Direct Link To This Post Posted: 20 December 2018 at 9:27am
Personally I’ve never had HD 15’s but my old 15” kicks which Bee built were similar to the turbo TSE215s but in singles. I had no problems with MT121s placed on them.
<a href='https://postimg.cc/CzdyFmLc' target='_blank'><img src='https://i.postimg.cc/CzdyFmLc/F885-F4-AA-79-CE-49-DB-8-F15-8-C759-A9-C1-B58.jpg' border='0' alt='F885-F4-AA-79-CE-49-DB-8-F15-8-C759-A9-C1-B58'/></a>
corell View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote corell Quote  Post ReplyReply Direct Link To This Post Posted: 20 December 2018 at 5:22pm
@boots :
https://www.limmerhorns.de/%C3%BCbersicht/ ; pricelist
308 IS a 312 + HF so defo not a problem to combine these!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Crazy Dane Quote  Post ReplyReply Direct Link To This Post Posted: 20 December 2018 at 5:51pm
Thats what i was thinking also, from the looks of it.
Maybe i should have a go with that combo then.
Would make a Nice and big box to look at with all those horns Embarrassed
As I can understand, they are made for B&C 12PE32 and DE700.
Is it critical to use these or could other drivers be used ad long as t/s are close to the same? I really like the sound of BMS HF drivers. Would love to put that in Embarrassed
Post Options Post Options   Thanks (0) Thanks(0)   Quote corell Quote  Post ReplyReply Direct Link To This Post Posted: 21 December 2018 at 3:47am
I Don't know of any 2" BMS apart from the coax...
TSP are not critical, the point is the mid cone has to fit the phaseplug.
Shoot Ralf limmer a message, he has tested a modern combination for sure. 12FW76 would be a killer mid driver for example.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Crazy Dane Quote  Post ReplyReply Direct Link To This Post Posted: 22 December 2018 at 8:54pm
I will give Limmer a shout and see what drivers of Today, will fit 🙂
More modern and Maybe better sounding 🙂
gen0me View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote gen0me Quote  Post ReplyReply Direct Link To This Post Posted: 23 December 2018 at 9:21am
Doesnt work..
Mixes: https://www.mixcloud.com/gen-ome/
Post Options Post Options   Thanks (0) Thanks(0)   Quote corell Quote  Post ReplyReply Direct Link To This Post Posted: 23 December 2018 at 9:24am
click on "Übersicht" in the top left corner
Father-Francis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Father-Francis Quote  Post ReplyReply Direct Link To This Post Posted: 23 December 2018 at 11:43am
Doesnt work..
try this one
Music is the strongest form of magic.(+45 31879997)blakmanpro@gmail.com
This page was generated in 0.250 seconds.
