  New Posts New Posts RSS Feed - Limmer horns combination.
FOO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote FOO Quote  Post ReplyReply Direct Link To This Post Posted: 23 December 2018 at 1:48pm
New user.. I have experienced some major problems with my e-mail and other accounts being hacked. So i have been forced to shut them all down and therefore i have made a new user here also..
Best regards..  Frank, now known as FOO.
Formerly know as Crazy Dane 🙂
Btw.. Cant find anything about other recommended drivers 🙂
corell View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote corell Quote  Post ReplyReply Direct Link To This Post Posted: 23 December 2018 at 4:48pm
a true mid horn benefits from a driver with as strong of a motor as possible. look out for B&C 12FW76, Oberton 12NMB600 etc (low qes)
but be aware that these drivers do nothing below the horn cutoff, no way of getting a few extra Hz with EQ as it would be possible with an "allround" driver in a large throat horn.
FOO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote FOO Quote  Post ReplyReply Direct Link To This Post Posted: 03 February 2019 at 12:50pm
Well... Thinking about what to do. I need a mid/high cab to get down to about 150hz. 180 might be okay.
Bins underneath will not be HD15 and Gsubs after all.
Instead it ended up to be some ported W bins.
So here is my thoughts..
Limmer 308+312 (1,5"+2x12")
Limmer 308+085 (1,5"+12"+15")
Limmer 308+15" in BR.
Limmer 308+15" horn loadet. TMS2-style.
Or Maybe go with a Limmer 042?
Limmer 042+085 = Limmer P3 (1"+6"+15")
Limmer 042+15" in BR = Limmer P2
Limmer 042+15" horn loadet. TMS2-style.
Enclosure cant be more than 50cm wide, and there will be used one mid/hi cab ontop of two Wbins.
For more power in the mid/hi section and better coverage, two cabs can be used ontop of three W bins.
Primarely usage will be EDM but live music can happen also.
Last, but not least i could also choose to go with RCF H6000 8" midrange  horn and do some RCF 4Pro 6001 clones or some TMS2-style cabs with that.
Any thoughts and ideas?
Edited by FOO - 03 February 2019 at 12:56pm
Keen View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Keen Quote  Post ReplyReply Direct Link To This Post Posted: 05 February 2019 at 3:59am
take the 15's out of the w-bins a build a reflex 215 to meet the Limmer 308.
seems to work rather well for these chaps;
Keen View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Keen Quote  Post ReplyReply Direct Link To This Post Posted: 05 February 2019 at 5:54am
btw, they're Kappa Pro LF's in the 215's
FOO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote FOO Quote  Post ReplyReply Direct Link To This Post Posted: 05 February 2019 at 8:09am
Wbins are 18", and quite nice.
doller View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote doller Quote  Post ReplyReply Direct Link To This Post Posted: 05 February 2019 at 9:19am
That vid did sound nice well chosen track me thinks. Would like to hear some nasty rock music see what happens then. Also if he needs 6x 215's to keep up with 2 horns maybe he needs better subs. ?
Keen View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Keen Quote  Post ReplyReply Direct Link To This Post Posted: 06 February 2019 at 2:30am
ok, cool
Keen View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Keen Quote  Post ReplyReply Direct Link To This Post Posted: 06 February 2019 at 2:36am
proper idm ratio would actually be more like two more subs to keep up with those horns. decently powered 12 inch mid horns are insanely efficient on axis, in band. like 110db +
Keen View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Keen Quote  Post ReplyReply Direct Link To This Post Posted: 06 February 2019 at 2:38am
and agreed, well chosen track Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote doller Quote  Post ReplyReply Direct Link To This Post Posted: 06 February 2019 at 10:30am
sorry Keen I was having a bit of fun there. I ment what I said about it sounding nice. I would love to hear some of those limmer horns. In Japan sadly I doubt it.
Keen View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Keen Quote  Post ReplyReply Direct Link To This Post Posted: 06 February 2019 at 10:58am
i would love to hear some too! but in Aus, i also doubt it
