Little or large |
Post Reply | Page <1234> |
Meat
Old Croc Joined: 05 June 2009 Location: Manc Status: Offline Points: 1514 |
Duplicate removed
Edited by Meat - 21 March 2018 at 1:30pm |
Dub Specialist Sound
Nothing wrong with the fane scoop too, with a slight mod here n there
yes full blown scoopist i am lmfao
I real realy realy dont know who to give this prized sticker too
lol |
Hemisphere
odc04r
Needs a cab photoshopped into background!
paulus
Old Croc Joined: 14 December 2005 Location: SOUTH BIRMINGHA Status: Offline Points: 3181 |
TRENDSETTER SOUND SYSTEM
matty w
Young Croc Joined: 27 August 2008 Status: Offline Points: 798 |
Dad , what's that place in the distance , in the shadows ......... Simba ,that is the scoop forum , u must never go there !! :D
Black to black , red to red , blue to bits ....
paulus
if was me would build emni scoop make 620 wide, then later on if you change from fane to bigger driver it will work on both , add 36mm mouth bracing and internal bracing boooom :) you will be surprised the out put you get from 2 full size scoops compared to "most" minis apart from the hardcore un free plan ones
Edited by paulus - 21 March 2018 at 2:16pm |
Aman Gebru
Registered User Joined: 01 February 2014 Location: Delhi Status: Offline Points: 350 |
Could always build the Super 914.
Works great with the Xb. |
nickyburnell
Oh stop it Mr Gebru. I was going to actually use the SL1200 plans at last!
Gone a bit quiet but the global horsrep use just went up a few %. Plenty used scoops about to hit the market, all they need now is some music that actually HAS 31hz.......Coat on Sir Edited by nickyburnell - 21 March 2018 at 4:24pm |
luton_soundman
Old Croc Joined: 03 August 2010 Location: Bedfordshire Status: Offline Points: 4539 |
uk dub has plenty. Certain producers pre warn you about the freq in some of their tunes and check you can reproduce it first
nickyburnell
Cool thanks
