  New Posts New Posts RSS Feed - Little or large
Little or large
Meat View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Meat Quote  Post ReplyReply Direct Link To This Post Posted: 21 March 2018 at 9:39am
Duplicate removed
Edited by Meat - 21 March 2018 at 1:30pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dub Specialist Sound Quote  Post ReplyReply Direct Link To This Post Posted: 21 March 2018 at 12:44pm
Nothing wrong with the fane scoop too, with a slight mod here n there
yes full blown scoopist i am lmfao
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dub Specialist Sound Quote  Post ReplyReply Direct Link To This Post Posted: 21 March 2018 at 12:47pm
I real realy realy dont know who to give this prized sticker too
lolLOLLOLLOLLOLLOLLOLLOLLOLLOLLOLLOLLOLLOLLOLLOLLOLLOL
Hemisphere View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hemisphere Quote  Post ReplyReply Direct Link To This Post Posted: 21 March 2018 at 1:29pm
Phase 1: Post on Speakerplans
Phase 2: ?????
Phase 3: Profit!
odc04r View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote odc04r Quote  Post ReplyReply Direct Link To This Post Posted: 21 March 2018 at 2:00pm
Needs a cab photoshopped into background!
paulus View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote paulus Quote  Post ReplyReply Direct Link To This Post Posted: 21 March 2018 at 2:14pm
TRENDSETTER SOUND SYSTEM
matty w View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote matty w Quote  Post ReplyReply Direct Link To This Post Posted: 21 March 2018 at 2:14pm
Dad , what's that place in the distance , in the shadows ......... Simba ,that is the scoop forum , u must never go there !! :D
Black to black , red to red , blue to bits ....
Post Options Post Options   Thanks (0) Thanks(0)   Quote paulus Quote  Post ReplyReply Direct Link To This Post Posted: 21 March 2018 at 2:15pm
if was me would build emni scoop make 620 wide, then later on if you change from fane to bigger driver it will work on both , add 36mm mouth bracing and internal bracing boooom :) you will be surprised the out put you get from 2 full size scoops compared to "most" minis apart  from the hardcore un free plan ones
Edited by paulus - 21 March 2018 at 2:16pm
Aman Gebru View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Aman Gebru Quote  Post ReplyReply Direct Link To This Post Posted: 21 March 2018 at 2:32pm
Could always build the Super 914.
Works great with the Xb.
nickyburnell View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nickyburnell Quote  Post ReplyReply Direct Link To This Post Posted: 21 March 2018 at 4:20pm
Oh stop it Mr Gebru. I was going to actually use the SL1200 plans at last!
Gone a bit quiet but the global horsrep use just went up a few %.  Plenty used scoops about to hit the market, all they need now is some music that actually HAS 31hz.......Coat on
BeerSir
Edited by nickyburnell - 21 March 2018 at 4:24pm
luton_soundman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote luton_soundman Quote  Post ReplyReply Direct Link To This Post Posted: 21 March 2018 at 5:28pm
uk dub has plenty. Certain producers pre warn you about the freq in some of their tunes and check you can reproduce it first Big smile
Post Options Post Options   Thanks (0) Thanks(0)   Quote nickyburnell Quote  Post ReplyReply Direct Link To This Post Posted: 21 March 2018 at 6:20pm
Cool thanks
This page was generated in 0.059 seconds.
