  New Posts New Posts RSS Feed - Little or large
Little or large
 Post Reply Post Reply Page  <1 234
Aman Gebru View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Aman Gebru Quote  Post ReplyReply Direct Link To This Post Posted: 22 March 2018 at 2:11am
Originally posted by Aman Gebru Aman Gebru wrote:
Could always build the Super 914.
Works great with the Xb.
Ha ha, not really.
As some may have speculated, 914 scoop needs PD1850 or V18-1000 or even stronger motor to work. Mush motor like 18 XB will have a massive dip in Pmax at 45Hz and will be down to 220 watts handling around 45Hz. V18-1000 will have no problems with Pmax and will be able to accept 1000 watts from 27Hz and up, all the way though its passband.
Yep you guessed it, black line is V18-1000, red is 18 XB.
The XB just doesn't have a strong enough motor to control all the air in the long horn behind it. Pmax isn't too important and shouldn't be 'the' deciding factor for output SPL, but if what goes in comes out then 1000 watts is going to make more noise than 220 watts, assuming efficiency is similar between both drivers.
Edited by Aman Gebru - 22 March 2018 at 2:13am
nickyburnell View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nickyburnell Quote  Post ReplyReply Direct Link To This Post Posted: 22 March 2018 at 7:47am
Well I could see that it would always want a bigger driver, but have to admit wasn't prepared for 220w. Little knowledge etc.  Shame, I was prepared for 500w and would have been happy at that as I have 650ish proper watts for each driver.
 Almost relieved, that's a lot of wood
MINTEVENTRESOURCES View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MINTEVENTRESOURCES Quote  Post ReplyReply Direct Link To This Post Posted: 13 September 2018 at 7:49pm
Has anyone built and used the Super 914? I am interested in this design any feedback on this one? What does this version sound like and will the Ciare SW18 work well in this box?
Mint Event Resources
UpComingSound View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote UpComingSound Quote  Post ReplyReply Direct Link To This Post Posted: 20 September 2018 at 9:03pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote MINTEVENTRESOURCES Quote  Post ReplyReply Direct Link To This Post Posted: 20 September 2018 at 9:18pm
Mini Scoop over Full Size???... this will start another war. I just want to know if anyone has really built the Super 914 and how does it perform... Seems you are saying build the mini over the Super 914.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dub Specialist Sound Quote  Post ReplyReply Direct Link To This Post Posted: 20 September 2018 at 9:32pm
whats the Super 914 scoop , pretty sure not many kno that scoop in the uk
Post Options Post Options   Thanks (0) Thanks(0)   Quote MINTEVENTRESOURCES Quote  Post ReplyReply Direct Link To This Post Posted: 20 September 2018 at 9:45pm
Thoughts?
welliriehifi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote welliriehifi Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2020 at 11:55am
Any word on the 914?
Looking to build some scoops
Post Options Post Options   Thanks (0) Thanks(0)   Quote Aman Gebru Quote  Post ReplyReply Direct Link To This Post Posted: 18 May 2020 at 3:34pm
Not heard of anyone building any, but looks like it will be a killer cab.
Try it and lets us know.
Maze View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Maze Quote  Post ReplyReply Direct Link To This Post Posted: 19 May 2020 at 10:26am
I'm not totally sure, but I think these guys use this scoop... https://www.facebook.com/Trueresonancesound/
TheAmazingGanjaMan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TheAmazingGanjaMan Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2020 at 8:32pm
True Resonance Sound system use the FTF 15" scoop
Burn Baby Burn Voice Coil Inferno
Maze View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Maze Quote  Post ReplyReply Direct Link To This Post Posted: 10 June 2020 at 5:13am
Ok, I searched the design on Facebook and they had posted about it. I'm also kind of curious about this design. Has anyone ran it through hornsrep?
