loading 1850 |
Post Reply | Page 12> |
lukehaze1
Registered User Joined: 15 October 2011 Status: Offline Points: 79 |
Posted: 25 February 2012 at 12:33pm |
When loading the driver to the 1850 is what is the best method?
I heard t nuts and bolts were the best but how would bolts work? as you would need to take the top of the cab to gain access to the other side of the driver to hold the bolts while you screw them in. basic question but i wanted to hear from people that have loaded the befor how they done theres thanks.
hmaudio
Old Croc Joined: 03 April 2009 Location: Nottingham Status: Offline Points: 3844 |
Thanks(1)
m8 tnuts for the 1850 and id use them instead of bolts.. its easier to tip the cab upside down when loading so you dont have the weight of the driver against you
This account is used by 2 people. |
lukehaze1
ok so it would hold better if i simple used t-nuts and screws?
hmaudio
Thanks(1)
tnuts and bolts yes
lukehaze1
sorry im confused. i thort u said use t-nuts instead of bolts?
Dub Specialist
Old Croc Joined: 30 December 2011 Location: Smethwick Status: Offline Points: 3230 |
Thanks(1)
yes as hmaudio has said (turn cab upside down) you got to use t-nut and bolts is the only way to go, what i do is i use the metal speaker/grill clamp upside down so it spread's the force/load over the metal clamp so the bolt doenst damage the mounting front baffle board and i use not the bolt itself only for final finish, i use the same size thread bolt just in case you slip and damage the head of the bolt..and i drive then all the way so the claws are tottaly flat unside of baffle board with a nice big handled screw driver for better leverage.... hope i make sense
Edited by Dub Specialist - 25 February 2012 at 2:59pm |
lukehaze1
thanks. so all i need is the t-nut bolt in the photo above and that will hold it well enough once put into place? .
what is a speaker clamp? what do you mean by this . i use not the bolt itself only for final finish |
Dub Specialist
speaker/grill clamp
Dub Specialist
lukehaze1
ok thanks mate that helps alot. much appreciated, what size are the t-nuts like 4 mm?
lukehaze1
lukehaze1
A step by step on how to fit these?
