Lockdown Audio - A 12v 3way Small Rig Build |
Page 123 14> |
Jack1991 ![]() Registered User ![]() Joined: 05 February 2020 Status: Offline Points: 406 |
![]() ![]() ![]() ![]() ![]() Posted: 07 May 2020 at 9:21pm |
I have always wanted to build something along the lines of this sort of thing for ages, but i knew absolutely nothing about it until recently when i joined a 12v audio facebook page in December and started to learn all about it. Then got pointed to this website too which has been even more helpful and full of great stuff! Then when all this coronavirus stuff come around i thought perfect time to start a project being on lockdown etc. After alot of reading around heres what i decided to go with Subs: 2x Tham 12's, The Box Speaker 12-280-W drivers Mids: 2x 10" Beyma SM110/N in custom enclosure Tops: 2x 1" P-Audio BM-D26 Mk2 30W Compression Driver with B&C ME10 90 x 60 horns in custom enclosure Crossovers: Convair Electronics 2-way Crossover 2.5KHz Butterworth Started to build the first Tham. I went with The Box Speaker 12-280-W as they have been rated highly for budget 12v builds. Also the Tham style sub looked like a fairly straight forward design so a good one to start with as a newbie. ![]() ![]() The sub driver next to my minirig ![]() Put the minirig facing inside the Tham π really pumped it out! Cant wait to hear the actual sub in there now!π ![]() Driver test fit ![]() Then after building the first one i started on the second, and now they are both fully finished. Just need painting which i will do all together when the mids and tops are completely done too. ![]() I added small strips round the inside edge to fit grilles onto. ![]() Edited by Jack1991 - 18 May 2020 at 2:11pm |
UPDATE: Then bought a Pioneer 8704 Class D 4 channel amplifier. Again these are highly rated on the 12v page. ![]() The plan with the amp is to have the 2x subs wired in parallel and bridged to 2 channels. So they will receive 150w each. Then the mids and top will have a passive crossover per mid top so 1 mid and 1 top wired to 1 channel and then the remaining mid and top to the final remaining channel. They will be 8Ξ© so will receive ~70w each. Started to plan mids and tops now! For the mids theres a lot more involved than i expected. Working out exactly the right volume of enclosure using the TS parameters of the drivers and getting my head around WinISD was a headache! But once that was sorted, working out how to then best make the enclosure to that size wasnt as bad. Google sketchup is really good to use for this i think. I havent ever used anything like that before so it was a bit tricky to get used to but gave me a rough idea what it would look like, much better than my drawings on paper anyway. Also its cool they have the measurements and sizes on there so you can literally make it to size. Heres my first go at what i want it to look like ![]() The mids with a view inside and ports ![]() Once settled on design i began to mark out and build ![]() ![]() ![]() ![]() ![]() ![]() ![]() Dry test fit ![]() I wasnt overly satified with the look of it though. I think the mids look too wide. The ratio doesnt look right. Also a few other guys on here helped me out by explaining how i should angle the mids and tops facing outwards to reduce comb filtering and beaming. So back to the drawing board. After messing around some more they now look like this. ![]() Much happier with the look of it now, also much happier that i have hopefully reduced comb filtering and beaming. 2 things i had no idea of and never heard of before. So lucky they helped me out before i glued it all together. πππΌ That sorted i glued the mids and tops ![]() This is as far as i have got for now. Next up is sand, router edges, fill holes, then more sanding. Edited by Jack1991 - 09 May 2020 at 1:36pm |
dnbpc ![]() Registered User ![]() ![]() Joined: 18 March 2010 Location: Manchester Status: Offline Points: 352 |
Looks wicked so far
Pick & Mix Soundsystem
Cheers mate! Update: This afternoon i have sanded, then routered the edges, i used a 6mm round bit, filled the screw holes, then sanded again, first with 80 grit, then 120 grit, then finally a sanding pad which i think is ~240 grit. ![]() |
Jo bg ![]() Young Croc ![]() Joined: 08 March 2017 Status: Offline Points: 526 |
Wish my lockdown frankenbox looked like theese, good job
Thanks mate im happy with it so far! πππΌ I havent seen your frankenbox Jo, do you have a link to a thread or photo? Id be interested in seeing it!
imageoven ![]() Old Croc ![]() Joined: 28 March 2007 Location: Scotland Status: Offline Points: 2139 |
Good work. I bet you'll be very happy when you get to hear it.
look fo 12v scrap subwoofer build, recent thread in 12v forum.
title says it all⦠actually i bodged up a better crossover from parts recovered from thrashed speakers and it behaves better now. If next week work is still low i have plans either to turn it into a bandpass , or to build a couple 100 liters Th. let's see how bored I am and ehat plans the Miss has... |
Just checked it out the looks decent! You done a good job seeing as its its recycled stuff too. Look forward to seeing what you end up building next.
UPDATE:
Done a coat of the Wood Dye on it all this morning. Only needs 1 coat of this. Then ill wait 24hrs and give it a coat of Danish oil, followed by another 24hr wait, then the final coat of danish oil. ![]() I went with Light Oak colour ![]() Then just standard Rustins Danish Oil to protect it and give a ever so slight sheen. Also brings the grain out nicely. I done them both on a tester piece of birch ply and it looks quite nice. ![]() Edited by Jack1991 - 09 May 2020 at 1:32pm |
Earplug ![]() Old Croc ![]() Joined: 03 January 2012 Location: Europe Status: Offline Points: 6802 |
Looking good. I do like the natural wood finish. Makes a change from black! ![]() |
Thanks man! πππΌ It does look quite orange at the moment but so did the tester piece. The danish oil darkened it a bit and made it look more 'woody' though.
Page 123 14> |
